Question about Microsoft Xbox 360 Console
My xbox will not read the disc, it does'nt sound like its spining
I dont think the motor that spins the disc is working
  • Anonymous Dec 09, 2008
    have same things nothing happen when i put disc in it tell me reading and after it tell me open the things for putting disc. i tryed all my game it wont work
Call up the xbox section of Microsoft (the number is on xbox.com) and talk to a representative if that doesn't work go to best buy or some company that fixes xboxs
Posted on Dec 09, 2008
Nt reading discs
If it spins up ,then says open tray
its a bad/weak laser or no spin up
would be a bad drive/wormgear motor.
The laser replacement cost 70.00-80.00
the drive swap cost 80.00-100.00
The laser cost 35.00-50.00 D.I.Y.
and the drive cost 40.00-65.00 D.I.Y.
Sep 08, 2009 | Microsoft Xbox 360 Console
Wont read games. Console says insert game into xbox 360 or open tray.
you might need to clean your laser, if they get dirty from playing games they won't read anything. When you put a game in the laser flashes once to read what type of disc is in, if its dirty it wont read anything and thinks there is no disc in it. If cleaning it dosen't help then you might just have to replace the laser. They aren't overly expensive and they are pretty easy to install as well.
Aug 09, 2009 | Microsoft Xbox 360 Console
Disc not spining in drive
sounds as the laser burnt out contact sony at 1800-345-7669 to get fixed or replaced
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 wont read disc
Listen to the drive if it spins and sounds normal then you will have to replace the laser inside the drive. If it's now spinning up then there's a problem with the motor and most likely will have to replace the motor or the drive.
Sep 30, 2008 | Microsoft Xbox 360 Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Cannot play any discs
call 1-800-4myxbox
if you dont have a warrenty you can buy a new one or you can mod it to see if you can fix it, i only recomend this if you are good with electronics.
Mar 18, 2008 | Microsoft Xbox 360 Console
Xbox CD Drive wont spin
The disk not spinning can be one of many things. first and foremost, did you have green lights on the ring or were there 3 red lights. If there were 3 red lights then you have hardware problems and we will need to get you the code of the problem. Now, if you have a green light then the problem most likely is that the laser has either gone bad or is out of adjustment. The voltage adjustment is not a hard thing if you have experience with a meter. HOWEVER YOU MUST BE VERY AND I MEAN VERY CAREFULL WHEN YOU HAVE THE COVER OFF OF A 360. It will take less than 5 minutes of run time to smoke the processor if you do not have all the airflow ducts and cover in place. TRUST ME ON THIS I repair game machines as part of my professional living. You can take a look at the laser and see if you get a red flashing of light when trying to read the disk. if you do not the laser is bad. If you do then it still may be out of adjustment. JUST BE CAREFUL TO NOT LOOK STRAIGHT INTO THE LASER YOU COULD DAMAGE YOUR EYES keep your eyesite off of a direct view. You will still be able to see if it lights up.
Another option is that the motor is bad. to know this you will have to wire the motor to a power supply and test it out. if it spins when hooked to an extenal supply then it is good.
It could also be that the circuitry on the motherboard that tells the motor when to spin is no longer working right. You should get some type of error on the screen or red lights if this is the case. but not always I have had 2 machines that said all was well when the motherboard was the issue. So, you have a little research work to do first. let me know about the lights!!
Feb 09, 2008 | Microsoft Xbox 360 Console
Non playable discs
Hi i had the same problem on my 360,
so i got a new laser off of ebay,
and that didn't fix it so then i read some fourms,
and found that my drive motor that spins the disc was broken,
so i replaced that and now the xbox is working like new again :)
Jan 04, 2008 | Microsoft Xbox 360 Console
CD Player Motor & Laser
If motor is NOT spining, laser can't read CD.
Oct 06, 2007 | RCA RS2503 Shelf System
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
