Question about Dryers
Kenmore elite 11084832200 tech sheet
In your post below you say that you can get a tech sheet, could you get one for me please?mmontana@sanjuan.edu Comment posted on Apr 08, 2008 Mdpjr,
Follow the advice I have posted and it should lead you in the right direction. If you need further assistance, please pst back and let me know.
PS There should be a tech sheet inside the dryer that will assist you parts location and troubleshooting. I believe you may have to remove the top panel to get to it. It's usually mounted to the side of the casing on the inside of the dryer. If you don't have one, let me know and I can tell you where to get one.
SOURCE: GHW9150PW0
punctuation would help
Posted on Jan 30, 2008
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite electric dryer 11084832200
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry clothes properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door:
a. Remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side.
b. On models with no lower kick panel, lift the dryer top and remove the screws that hold the front panel in place.
c. The Kenmore Elite & Whirlpool Duet have a couple of screws under the bottom edge of the panel under the door that you need to remove.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Posted on Mar 31, 2008
  • 103 Answers
SOURCE: need poer cable for hp photosmart 7762 printer
Try here
http://www.ciao.co.uk/Hewlett_Packard_Power_adapter__6481729
Posted on Apr 22, 2008
SOURCE: maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Posted on Jun 17, 2008
I can't find my users manual and I am getting an rL code on my Kenmore he5t front load washer.. Can you tell me what that means please?
"rL" indicates garments were detected (by weight) inside the wash tub during a Cleaning Cycle. Anytime the cleaning cycle is selected, the wash tub must be empty. Press PAUSE/CANCEL and inspect the wash tub and rubber seal (bellow) for any loose garments. If the error reappears, try unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes, resetting the CCu can clear momentary program glitches. If the error reappears following a CCU reset, you may have a legitimate issue.
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use. If you have any questions, please post back and let me know. I hope this helps you.
May 09, 2011 | Kenmore Elite HE5t Washer
My kenmore elite front load washer model # 110.46742702 displays code F 27. what does this mean?
"F27" is an Overflow Detect error code. The following link explains the code in detail and lists the steps to take to try to resolve:
http://www.fixya.com/support/r3608602-f27_error_code
A simple thing to try before assuming you have a component failure is to UNPLUG the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). In some situations these error codes can be erroneous and a simple CCU reset will correct the problem. If the error reappears following a CCU reset, then you have a legitimate problem that you will need to troubleshoot to resolve.
NOTE: Each one of these washers come with a technical data sheet enclosed inside the equipment cabinet. The tech sheet lists all error code definitions, diagnostic procedures, troubleshooting data and wiring diagrams. You may have to refer to the tech sheet to assist in troubleshooting this problem.
The tech sheet is located behind the lower toe panel directly below the washer door. To access, locate and remove the screws under the bottom front edge of the panel. For better access to the screws, you can prop the two front feet of the washer up with a 2x4. With the screws removed, the panel should drop down, then come off. The tech sheet will either be located directly behind the toe panel or affixed to one of the interior cabinet walls.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
Wiring Diagram for connecting ccu
If you are referring to a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and WIRING DIAGRAMS.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Oct 21, 2010 | Washing Machines
How do I reset my Kenmore elite front loading washer?
You can clear most common program glitches by unplugging the washer for AT LEAST 30 minutes. This will reset the Central Control Unit (CCU) and correct most momentray glitches. If the problem reoccurs, then you may have a legitimate problem. Take note of any error codes that may be present on the front panel display.
If you do experience any reoccurring errors, the error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Aug 13, 2010 | Kenmore Elite 45986 Front Load Washer
What happen when A kenmore oasis he washer has no power. Is there A reset button
In them tech sheets is some info on what to do in case that puppy appears to be dead in the water. OASIS TECH SHEET
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite he3 model#110.42822201 washer; where can I get a schematic? Graham
Every one of these front loaders come with a technical data sheet inside. You need to remove the lower toe panel directly below the door to access it. The screws are located under the bottom front edge of the washer. You may have to prop the two front feet of the washer up to access them (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off. The tech sheet will either be located directly behind the panel, or affixed to one of the interior cabinet walls in an envelope. The tech sheet includes all troubleshooting data, error code definitions, diagnostics procedures, test points and wiring diagrams. I hope this helps you.
Jan 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Received an error code dl f on my Kenmore Elite 45986. Replaced the locking mechanism and I am still receving the same error and results. It just clicks and gives this error code. Thanks "dl F" error code...
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 11, 2009 | Kenmore Washing Machines
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
141 people viewed this question
Top Dryers Experts
