Question about Reddy R70ET Utility Heater
Heater not turning on
I switched the thermostat to heat and nothing happened. it set at 68 and it was 63 in the house, i waited and nothing happened. i turned the fan switch to on and the fan works. i switched to cool and lowered the setting and it kicked on. any idea why the heater won't kick on?
  • casaintsfan
    casaintsfan Dec 09, 2008
    repalced the thermostat and getting the same problem
Check to make sure gas valve has at least 24 volts
Posted on Jan 04, 2009
    Genius:
  • 1,199 Answers
The thermastat needs replaced!
Posted on Dec 09, 2008
Goodman Model # GMC070-4b
is the thermostat set for heat and you have power going to the unit correct
Jun 05, 2017 | Goodman GMS90703BXA Heater
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
I changed the batteries in the digital thermostat but the heat won't come on. we woke up and the batteries were dead so we replaced them. we have checked the breaker and the switches on the unit but no...
Turn the system off,at the breakers,and turn the thermostat off.Leave it for 15 minutes,then turn the breakers on,and set the thermostat,and wait to see if it resets,and come s on.
Jan 17, 2010 | Honeywell Electronic Programmable...
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
On my honeywell rth230b thermostat, sometimes when i try to turn on the a/c, the snowflake will just blink and the a/c will not kick on. why does it do that?
They do that sometimes as a timing feature when going from heat setting the to cool setting or vise/versa. It should not do that when the thermostat is off and then you switch it to cool. Make sure the batteries in the thermostat are fresh. And make sure the thermostat is fully seated on the housing. Also check the wires are fully inserted into the connections on the thermostat housing and the wiring is correct.
Sep 14, 2009 | Honeywell Electronic Programmable...
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Reddy R70ET Utility Heater Logo
178 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
