Wont Print a Large PDF File
My printer will not print a 66 page PDF file, it will only print the last page. If I make a 4 page document will only a letter on each page it will print all pages. Not sure if its the printer or a problem with my Laptop.
  • Martin Ryan Dec 11, 2008
    I have a lexmark x3580 and a HP Pavilion Entertainment PC. I still have well over 40G's of memory on my laptop as well.
  • Anonymous Dec 12, 2008
    I have printed the first ten pages and then the next ten and so on then i printer the last 16 pages and it worked like that. I spoke to a friend and they said it might be the memory within the printer that is causing the fault.
  • 169 Answers
You don't say what kind of printer or computer so it's a little hard to narrow down what is happening. That said, it sounds like you've running out of disk space while the print driver is trying to make data to send to the printer. If you can print the 1st few pages (try 4, then 3, etc.) then this is almost certainly happening.
Check how much free space is available on your hard drive.
Carl
Posted on Dec 10, 2008
  • Carl Gehrke
    Carl Gehrke Dec 12, 2008
    Well 40Gb of hard disk space seems like enough to spool a large document. So next is to determine if there is something in particular about this document or if you're hitting some limitation of the printer driver.
    I checked the Lexmark web site and found they do have an issue with printing multipage documents on systems running Windows Vista. It didn't sound to me like this was your problem.
    Are you using the same program when you make the 4 pager that does print? I'm thinking that you're using Acrobat Reader for the 66 page one and something else for the 4 pager. Sometimes different programs have different problems with printing.
    Can you print this same 66 pager in reverse order? Some print drivers call this "collated" other call it reverse order printing. No matter what it's called on your printer, we need to check that this isn't making any difference.
    Can you print some pages of this document less than all 66. This is related to but not the same as the reverse order test above. Try printing from page 64 to the end, from 13 to 17, or anything else that isn't the whole document but is multiple pages.
    Can you print other large (multipage) documents from this same program?
    In the end one of these things is going to be the truth:
    1) There is something about this particular document that makes the bad thing happen.
    2) There is something about this particular copy of this document that does the bad thing.
    3) There is something about this program that doesn't play well with large documents.
    4) There is something amiss in the way your OS interacts with the print driver.
    Once we figure out which problem is going on we'll be able to come up with some sort of workaround.
    ttfn,
    Carl
  • Carl Gehrke
    Carl Gehrke Dec 13, 2008
    Guest makes a good point, sometimes the printer does run out of internal memory when printing these sort of non-trivial jobs. Usually when this happens it's because the document has some memory intensive to render object in it and so unless that particular page is printed we don't see the problem. A quick test for this is to see if the document prints at the lowest quality settings better than at the default ones, if you get more pages you're on the right track.
    Carl
Print pdf files
Try to print another type of document, i.e : doc, jpg.
If it 's no problem at another type of document, the problem is on PDF file ( not allowed printing, security setting), or on software for opening PDF file.
Oct 01, 2013 | Epson Stylus NX100 InkJet Printer
Tip
Scan multi-paged document and create a single PDF document
1. You need to install a PDF printer driver on your computer first.
There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
To download CutePDF printer driver (freeware) click on this link :-
http://www.cutepdf.com/
2. Using your computer SCAN the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scaning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document if you require but not needed.
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
on Jul 07, 2011 | Computers & Internet
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
5. Close the scanner when finished scanning.
7. Save the Word document (not necessary).
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
Pdf file too large: 1-2 pages about 1 MG.
Try and print the document 1 page at a time, upgrade the memory in the printer if you can, and most importantly; make sure that this is not a false error because the PDF requires postscript fonts to be installed you don't have installed on your printer. You can do this as follows.
Their are 3 standards for postscript, go to the manufacturers website and download the newest version of the postscript driver, not PCL. Many printers go nuts if running on an installed PCL driver and asked to print a PDF. If all else fails, this typically gives a lot of false errors.
Nov 08, 2009 | Brother MFC-8860DN All-In-One Laser...
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
HP OfficeJet 6400 sorts pages automatically when scanning.
When you go to print make sure you have the print settings to "collate".
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Mar 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
625 people viewed this question
k24674
jasbo
jasbo
