Question about Nortel 1140E
Nortel 1140E IP Phone, Expansion Module 1100 series not working
We purchased the expansion module that allows us to see the other phone lines in the office (to see being on the phone, or not). After connecting the module to the phone, and plugging in the power cord, the unit lights up, just like the phone system, but displays:
i00v138
v115
A nortel representative on the phone, uploaded all the extension information for all the module quick buttons (18 buttons), though nothing else displays, and none of the buttons produce any sort of action.
Any help on how to make this module work?
  • 1 more comment
  • Anonymous Mar 03, 2009
    I'm sure it is. The Nortel phone was shipped by the same company that sold us the phone. They indicated that the module and phone go together.
  • Anonymous May 12, 2009
    same problem, IP 1100 add-on not working
  • ryanmoloon May 14, 2009
    I have a CS1000 and i program the expansion module, but it still nothing.
If you're running on a hosted PBX, the expansion module will not work. It only works on premis based systems.
Posted on Mar 24, 2009
Is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Posted on Mar 03, 2009
NORTEL IP 1140E + BT 2 WIRE ROUTER.
Try a different phone on the same router, does that fix it?
Dec 20, 2013 | Nortel 1140E
Can two way speakerphone be disabled on a 1140E?
Yes - download the opperator manual from net at
http://www.nd.gov/itd/files/services/voice/1140e-user-guide.pdf
You can use the mute feature to block 2 way speech
Jul 05, 2012 | Nortel Avaya / Ip Phone 1140e - Ntys05bce6
I have added cisco 7916 expansion module to 7965 cisco phone.Now when i started the phone,phone works but expansion module screen shows cisco logo and lights continuously flash.
I know it may be late (definitely late), but have you defined in the CallManager, that your phone has a "side card"? If CallManager does not know that it has to push an additional firmware to a particular phone, it will not work.
Good luck,
Mike ' CCNP, CCVP, CCSP, CCDP, MCSE, etc.
Headset Adapter Co.
Headset Adapters for office phone system
Mar 21, 2011 | Cisco Systems - Unified IP Phone...
Reset a 1140E IP Phone
If you are running C6E or later firmware, then the following keypad sequence is used to reset all provisioning paramaters to a "factory default":
[*][*][7][3][6][3][9][MAC][#][#]
Where MAC corresponds to the MAC address of the IP Phone which can be found on a label on the back of the IP Phone.
Since a MAC address can contain the letters A-F, then letters A/B/C can be entered via the [2] key on the dialpad, and letters D/E/F can be entered via the [3] key.
For example, an IP Phone with MAC address 00:19:E1:E2:17:12 would be reset to "factory default" when the sequence **73639001931321712## is entered on the keypad.
Apr 08, 2009 | Nortel 1140E
Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Dec 18, 2008 | Nortel 1140E
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Jan 10, 2008 | Nortel 1140E
1140E Problem
Is it the only IP phone? Howstable is the network?
Nov 22, 2007 | Nortel 1140E
Nortel 1140E Logo
1,032 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
