Question about Dryers
I have a Kenmore model 86650100 electric dryer. The dryer will come on, but there is very little heat produced, regardless of the setting. I have checked all the air ducts to insure they are open and the air is flowing. I am assuming the problem is in the heater element, since I am getting some heat, not the fusable link. But, I would like to have a schematic of the location of the dryer parts, before I start taking the back off the thing. Where can I go, online to get a schematic of this dryer?ThanksCliff
  • cd88 Dec 13, 2008
    Thanks for the suggestion. I tried finding the diagrams, and even sent an email to them about diagrams, but they did not respond to my query. However, the problem was fixed simply. I found that one of the 110 V wires in the recepticle from the breaker box was detached and I was only getting half the voltage to the machine. Hooking it back up fixed the problem.
    Problem Solver:
  • 14 Answers
Try going to appliancepartpros.com they have good drawings on most models.
Posted on Dec 09, 2008
Kenmore dryer, 417.93042202, just replaced gas coil set, but now we only get high heat, regardless of the heat setting.
Those coils serve to supply the gas to the burner and do not have anything to do with the temp. That is the job of the control thermostat. It mounts on the blower housing. Older models have a bi-metal klixon type control. Typically having 4 wires. 2 small wires which heat up the klixon so that it will shut down faster for knits and perma. 2 bigger wires which go to the gas assembly. Newr models have a thermistor. I would be a replacing the control stat stat. LOL
Sep 13, 2012 | Kenmore Sears Dryers
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
10 year old Kenmore dryer Series 80 suddenly has stopped producing heat. Vent is clean. What else can I try?
On a gas model dryer those coils seem to die when heated when they have a little age on em. So if the ignitor works and the dryer does a little bit of heating then fails and it is gas then those coils are the problem. On an electric model the element will get brittle with age and die but if your dryer is suffering from air restrictions it may have had a limit trip on it.
I have a service manual and more of a Kenmore /whirlpool style dryer HERE
Jan 18, 2011 | Dryers
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Poor heat
Hi, Have you checked the venting to the outside? Is this gas or electric? If it is gas, it could be coils on top the gas valve. I want to help.
Vic
May 16, 2009 | Kenmore 73952 Gas Dryer
Kenmore Electric Dryer Heating Problem
Most heat related problems with dryers are attributed to poor air flow. I would start there first in determining if you have a ventilation problem BEFORE replacing any components. If you don't, and you have a clog somewhere, you will end up with the same problem and repeated failed components. The following link gives some useful advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention the first major paragraph that discusses the ventilation. Follow the advice and attempt to run the dryer without the exhaust vent attached, first. If the dryer begins to heat, you may have gotten lucky and avoided any failed components. However, if the dryer still does not produce heat, you probably have blown a component in the heating circuit. More commonly, the thermal cut-out (TCO) blows. Make sure you check ALL heating circuit components before taking my word for it, just to be sure. Reminder: If the TCO is blown, it is highly recommended that you replace the hi-limit thermostat at the same time. In many cases, these components are sold as a set.
Go to searspartsdirect.com and type in your model number as "110.62972100". Look under the "Bulkhead" heading for item number 47 (This is the TCO/thermostat set I am referring to). Refer to this drawing as a reference for your component identification (the Heating Element is listed as item 14). I hope this information helps you. Let me know if you require additional assistance.
Oct 27, 2008 | Kenmore 63942 Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
97 people viewed this question
Top Dryers Experts
