Zio Corporation  CD-RW Burner
Problem for Zio Corporation (DM-3000) CD-RW Burner
How to Restore a CD?
By LiZzIe - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
herself
Rank: Apprentice
Rating: 0%, 0 votes
If a CD or CD-ROM gets scratched, it often becomes unplayable. Don't write off your favorite album or computer game yet, though.
1. Clean your disc so that you can see where the scratches are. Holding the disc by its edges, wash it with mild soap and water and pat it dry (don't rub it or you'll make more scratches). Sometimes this is enough to make a disc playable again.
2. Examine the clean disc carefully under a good light. Scratches that are likely to affect disc play run parallel to the edge of the disc. Vertical scratches that run between the center hole and the edge are usually not a problem.
3. For minor scratches, carefully clean the clear plastic that protects the aluminum inside the disc. Use a soft, damp cloth and a small amount of very mild abrasive cleaner--plain white toothpaste, metal cleaner or plastic cleaner. The key is not to make new scratches. When polishing or cleaning, always rub gently from the inside of the disc to the outside (see illustration). That way, any scratches you make will be the harmless vertical kind.
4. After wiping away a scratch, clean the disc again, let it dry and try playing it again. If it still skips, repeat the process.
5. If your disc is severely scratched, try using a combination abrasion and waxing technique with a commercial disc-repair solution.
Was this helpful?
Yes
No
Solution #2
posted on Feb 09, 2008
Not Rated)
Junoon007
Rank: Wiz
Rating: 82%, 399 votes
hi
Install the software ISO BUSTER from www.isobuster.com/ and read the instructions from help menu. This software will extract the files from scratched Cd's and DVD's. Try this.....
Cheers!!!!!
Was this helpful?
Yes
No
Popular Solutions for Zio Corporation CD-RW Burner
Questions and Unsolved Problems for Zio Corporation CD-RW Burner
Do you recommend Zio Corporation (DM-3000) CD-RW Burner?
Answer
Answer
which type recover my pc drive it is loses in running computer
Answer
I have same pictures in a folder, which are already burned some weeks back in a writable CD.It... (More)
Answer
my cd's are not being read after i burn or copy them
Answer
my cd's are not being read after i make or copy them
Answer
my cd burner drawer will not open it is a memorex
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
