Question about Legacy Audio LA470 Car Audio Amplifier
Legacy LA470 red series2
One day the bass just quit and the protect lite came on and wont go off.The fuse is good, no burnt smell,just no sound...
  • Jimmy Driver Feb 27, 2007
    One day the sound just quit and the protect lite came on and wont go off.The fuse is good, no burnt smell,I took the top off and everything looks new,no burnt spots anywhere, just no sound. Please try and help thank you
  • 156 Answers
This can be caused by a blown subwoofer.
Posted on Mar 07, 2007
2003 ram2500 5.7 hemi wont shift from 2nd to drive or overdrive
The shift linkage could have come undone or be damaged (hence the pop sound) also could be an electrical fault (fuse making a pop sound when it fails)
Feb 08, 2014 | Dual 03-09 Dodge Ram Quab Cab 2500 3500...
I plugged up an Legacy LA470 300x2Ch amp. It stayed in protect mode and never changed to power mode. I checked the power and ground, works fine, then remote, works fine. I then checked the output to the...
I would suspect if the amp is known to be good, that someplace you have a shorted speaker wire... possibly someplace the insulation is cut through or maybe you have a bad connection with frayed strands shorting out the speaker. Use an ohmmeter to check the resistance between each set of speaker leads and then to ground.
Mar 26, 2011 | Car Audio & Video
Protect light is on ,no sound?
Make sure you have a good ground connection. The ground wire should be solidly connected to the vehicle chassis in a paint-free location. If the ground is connected badly, the protect light will come on.
Mar 08, 2011 | Legacy Audio Legacy - Red Series: 2...
KAC9103d been running great for a year, factory refurb. for a month been losing sub output. checked all connections again, everything good. Turned on went driving 15 minutes later lost bass ckd again red...
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
Jan 22, 2010 | Kenwood KAC-9103D Car Audio Amplifier
Wont shift out of 1st
It sounds like the bands inside the transmission are burnt. one way to check is pull you trans dipstick and smell the fluid and see if it smells burnt and the fluid should also be bright red. i have burnt a few trans myself and they did that.lol
Apr 18, 2009 | 1990 Chevrolet C1500
Won't work after re-installing Boston speakers
would try it with the correctly rated fuse as there may not be enough wattage / current to power the bass unit with a thin wire.
Also how long ago was it flooded as it may take quite a while in a warm area to dry off completely ?
Apr 11, 2009 | Boston Acoustics BA735 Computer Speakers
Amp Was Extremely Hot and I Have Now Lost All Sound
Where was the smell coming from? The amp or the sub?
Do you have an ohmmeter to check to see if the sub's voice coils are still intact? Can you try driving the subs with another source to verify they are ok? We need to eliminate the variables here.
If the subs are okay then it's obvious that the problem is in the amp. I'm not sure if there are any protection devices internal to the amp, but I am sure if you remove the cover from the amp and if it was amp that was producing the burnt smell, you'll have no trouble visually identifying where the problem is in the amp. Most likely you'll find a part that is discolored or black & burned.
Usually a smell like this from a solid state device indicates a component has been overheated and if run long enough in this condition will fail.
- Jim
- Jim
Jul 07, 2008 | Alpine 600W Class D Mono MOSFET Amplifier...
Protect LED on
this is a basic procedeur just look for any short between pins of each component.
Apr 11, 2007 | Legacy 600 WATT 2 Channel MOSFET LA470 Car...
Legacy Audio LA470 Car Audio Amplifier Logo
125 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
