Question about Canon BubbleJet i9950 InkJet Photo Printer
Service manual vanon i9950
Service Manual Canon i9950 Part Canon i 9950 i am loking the things. anybody can help me give it to me my printer has blinking and not responding i had try the reset system but still cannot efective and my printer still not working. i try to service by my self and i think i can do it but i must have the service manual. then later i will tell and help anybody use the same brand canon i9950 to cut their cost to maintanining the printer. please help me and i hope it please send to my email the manual please. [email protected] zamzam i am malaysian thanks
  • 4 Answers
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power
button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in either orange or green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
Time(s) LED
Function
Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See Section 3.5 Verification Items, (1) Service test
print.
2 times Green EEPROM information print See Section 3.5 Verification Items, (2) EEPROM
information print.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings After performing step 5), and follow the Destination
settings procedures.
6 times Green Print head deep cleaning
7 times Orange Media sensor correction After performing step 5), and follow the Media sensor
correction procedures.
8 times Green CD-R test print Not used in servicing
9 times Orange CD-R print position
correction (horizontal)
10 times Green CD-R print position
correction (vertical)
11 times
or more
Return to the menu selection
For full Service manual I've uploaded it here:
http://www.megaupload.com/?d=BLC9L7OU
Posted on Mar 26, 2009
If you go to http://printer1.blogspot.com/2009/01/canon-i9950-service-manual.html there is a link to a free downloadable pdf Canon service manual that should solve your problem.
Unfortunately, although it claims to offer comprehensive dismantling instructions, it doesn't and it couldn't solve my problem. I am trying to replace the waste ink pad in the base. I've succeeded in removing the top casing and have the printer open. I'm now trying to find which specific screws need undoing, out of the many visible, in order to be able to detach the entire printer engine from the base tray. I don't want to undo unneccessary ones and cause more problems than I'm trying to solve !
Cheers
Peter
Posted on May 19, 2009
My Canon i9950 printer needs your help for the following problems:
After cleaning up the absorber, the printer is blinking red and yellow and keep saying the waste
absorber needs to be replaced.
Posted on Nov 12, 2008
  • 944 Answers
Go to this link; http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=bj&country=SG and select i9950 under "select model" there is a lot of technical information there, but no true technical manual. Contact them through the site and they will tell you where to get a manual - for technical manuals you sometimes have to pay, but not too much i think. I hope this helps :) Jangan ten shen lah salam
Posted on Mar 24, 2007
SOURCE:
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
Hi, I have a Canon i9950 that is marking all it's prints with black littles lines every 1cm down the left side of the page. Does it need service?
Hello you can try this may do it
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Canon i9950 InkJet Printer
Canon 4300 feed repair
First you need to have a service manual to open printer or else you will damage the printer and also you can get part no also:Please click on this link to get one :
http://www.nodevice.com/manual/newmans/Bjc4300spdf/get13334.html
Good luck...
Sep 07, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950 colour deterioration
You can try changing cartridge but that would help little since the print head on canon printers are on the printer itself. Although you can give it a shot first since that would definitely be the cheaper option.
Aug 21, 2008 | Canon i9950 InkJet Printer
Canon i9950 feed issues
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950: Full waste ink absorber
Dhedik maybe this action can solved your problem Reset Waste Ink Counter printer Canon i9950 :  1. power off  Printer
2. Push and hold resume  button and push power button
3. Hold  Power button and release Resume  button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and  stop.
6. When green light on, push resume button 4 x
7. Push  Power button and printer will off, if that isn't off, push power butto again until print off position.
ok good try, don't forger to vote me, Fixya
Apr 02, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
I9950
sure...on the front panel, under menu, you can select that function. The manual will walk you through it. That's pretty standard on most good printers, these days, and I always do that when working on printers.
Got Backup?
Feb 08, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Canon BubbleJet i9950 InkJet Photo Printer Logo
2,324 people viewed this question
Clive
Clive
old marine
old marine
Ekse
