Question about Belkin Computers & Internet
Have belkin n router, want to network laptops to transfer files
Hello, I have 3 home laptops and want to send files from one to the other with out using email. I have a belkin n router, can yuo tell me how to network them together?
thanks
  • 128 Answers
Connect the laptops to the WAN - set up a shared folder or map a drive so that each laptop can see it. The wizard for the router will help you set the router up - and use Windows explorer to setup the shared/map drives.
Posted on Dec 10, 2008
How can i install my wireless router to other laptop?
The same as 1st laptop.
1. Locate the wireless-network-connections option
on your computer or wireless device.
2. Select your Belkin Router from the list of available networks. You
can identify your Belkin Router by locating the network name
(SSID) from the card located underneath the foot of your Router.
3. Enter your network password (located on
your network information card).
Oct 06, 2012 | Belkin Connect N150 Wireless N Router
Hi I have just installed a brand new Belkin wireless router and it works great with all computers and laptops in the family (including Apple products) apart from my daughters laptop...she has a toshiba...
Check the main computer you set up the network router with...you may need to go to the network status and tasks in control panel...click on this...then you will see a map of all the network devices connected...find the belkin router and click on it...in this window there should be a tab called wireless properties..click this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb drive..you can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
Jan 04, 2011 | Belkin (F5D8231-4) Wireless Router...
Can't see other computers in network
first,check properties of LAN of all computer...then check the FILE/PRINTER SHARING
second,OFF all windows firewall..
now,open your windows explorer to view other computers... jaz type in the address bar \\<computer name of ip address> of other computer you want to view
Oct 28, 2009 | Belkin Computers & Internet
Problem with downloading router driver/firmware
You don't need software for the router. Is your wireless encrypted or open? Just view avaiable networks with your xp machine and choose your network to connect to. If you do have an encrypted signal use the vista machine and type in the ip address to the router in your browser window. I think belkins router ip is 192.168.2.1 or 192.168.0.1 Hope this helps, let me know
May 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Connection problem
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Jan 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router , I need to find my network key
192.168.2.1 is the web access page for the belkins router. You can also just download the software from belkins website for you model of router. Run the program and redo the network key.
Let me know
comier957
Aug 10, 2008 | Belkin (F5D7230-4) Router (587009)
Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
Aug 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to block my neighbors from using my wireless connection with my belkin 54g
you need to get in the router home page and click on the wireles lan icon & click on configure
you set up a network id for the laptop you call call your network id anything ,a name with numbers or letters with number
and a security wpa key not a wep key dont use that one use wpa key then click apply at the bottom when you have set up your network id and security wpa key
then you put a wireless usb adapter on the laptop you install the network drivers on the laptop for the wireless usb
then you click on the network icon in the taskbar by the time on the laptop right click on it go to properties then you click on view wireless networks then you click on advanced tab you put in the network id and security key that u set up on the router home back then you click apply & ok then you click on view wireless network's your see your network id click on that then click on conncet
if you have a wireless card in the laptop just
if your network cuts out at any time just right click the network icon by the pc time
and click on repair that is on the 2 computers you can do this then windows xp will repair the
network for you and it dont take long at all
if you cant set that up
your be better off if you get you (isp)server to help you set all that up
transfer files from pc2pc
have the 2 copmuters on the wirless network then
Dual login yahoo messenger files trasfer from pc 1 to pc 2
on pc 1 you login a yahoo id then on pc 2 you login another id
then you add to friends list then you get yahoo id 1 to pm yahoo id 2 then yahoo id pm back yahoo id 1 then you click on the send file icon then you send files from pc1 to pc 2
your send files over from pc 1 to pc 2 verry fast ,dont go in a chat room while your doing the file trasfer coz this will only slow down the trasfer
Jul 26, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Router down when copy files
Check in your routers settings via your browser that the file transfer speed is no higher than 54 mbps, as it may be set at 108 mbps or 125 mbps as a 'g' type router should be, but your wireless network adapters can only work at 54 mbps and are crashing the transfers.
Feb 28, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
73 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
