Question about Tech Solution TS-4500 Shredder
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
  • Anonymous Mar 08, 2009
    Same problem with the TS-8000--Runs continually with switch in the on position and no paper being fed into machine. Maybe it is a sensor or needs some part replaced and soldered ? Can someone help with an answer ?
    Problem Solver:
  • 6 Answers
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Posted on Jan 03, 2009
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
These are made by Winsource Industries http://www.winsource-hk.com/ The contact information is Hong Kong. I haven't had any luck getting a replacement for one with a Limited Lifetime Warrany.
Good Luck -
Jan 25, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Need parts for my techsolutions paper printer TS 4500
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 10, 2009 | Winsource Tech Solutions TS-4500 Cross-Cut...
Only runs in reverse
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Jan 01, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
Problem ts 6000
Nov 30, 2007 | Tech Solution TS-6000 Shredder
Need to re-adjust the paper sensor switch
I have one of this model. You can see 6 holes with screws in them. The 7th hole is under the serial number paper tag near where you see a deformity of the plastic. I have not taken it apart & I don't know if the sensor is adjustable.
May 22, 2007 | Tech Solution TS-4500 Shredder
TS4500 Shredder
there is one screw under the s/n sticker
May 08, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
144 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
