Question about Epson Stylus CX6600 All-In-One InkJet Printer
My cx6600 has new ink cartridges and acts like it is printing but the pages come out blank!
  • Anonymous Dec 16, 2008
    Printer has new cartridges, printer recognizes that cartridges are full put no ink is eposited on on paper.
  • Anonymous Jan 17, 2009
    Printer has worked fine for 3 years. Suddenly won't print any colour although it makes all the right noises. Sheets come out blank.
Try taking a new cartridge out and shaking it ( with your finger over the hole that the ink comes out) and then put it back in.  Also make sure that the tape that is over some cartridges' printing area has been removed.
Posted on Dec 13, 2008
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My dell 720 printer has a new ink cartridge, acts
Take the plastic strip off the ink jet cartridge before putting the thing in the printer.  Check the ink jets to see if they are clogged.
Oct 25, 2009 | Dell Inkjet 720 Printer
Not printing
try to check if the type are not remove in the cartridge then check if the printer head cable of the print head is ok.. ^^ if not you need to tighten it up.. or maybe the pritner head cable is damaged
Feb 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson cx6600 printing only magenta even with new cartidges
Try remove and shake the inks and reinstall it back in and test to print. If you have tried more than 4x with the head cleaning it might be your ink pads inside the printer is clogged. Is this still under warranty? You have to call Epson they might help you out with it.
Oct 11, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing blank pages
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
Mar 25, 2008 | Lexmark X1195 All-In-One Printer
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
I only need to print black
ad hohumincali
as all the cartridges are NOT empty, Head Cleaning (repeatedly) may solve your problem.
Nov 13, 2007 | Epson Stylus CX6600 All-In-One InkJet...
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
