Question about Canon EOS-AE-1 35mm SLR Camera
Blank Film Developing
I have a recently purchased Nikon FG and after shooting an experimental roll of film, took it to get developed. However, the film was blank. Any ideas/suggestions?
  • hvelez02 Dec 10, 2008
    That's what i thought after reading an online copy of the instruction
    manual. I loaded a second test roll and made sure it was loaded
    correctly this time and will get it developed tomorrow. The shutter and
    other mechanics work correctly so I'm hoping that I simply loaded the
    film incorrectly. Thanks and i'll let you know as soon as i get it
    developed if it works!
    Scholar:
  • 95 Answers
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Posted on Dec 10, 2008
Why is film clear after developing? Using bulk load Tmaxx 400
Sounds like the camera isn't working. It would appear the shutter doesn't function because you have no images at all. I would open up the camera and check this. (Empty of film of course).
Feb 25, 2015 | Nikon N75 35mm SLR Camera
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Feb 16, 2011 | Nikon F100 with 28-80 and 70-300 lens 35mm...
35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Sep 03, 2009 | Photography
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Pictures did not take
Check for the settings of the camera .Open the back door of the camera now press the button seeing through back, if the shutter opens up and closes everything is correct.
check for the film.
Apr 01, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Developing pictures
depending on the type of film you are using and where you are taking it could be the problem. if you are using professional film and taking it to a pharmacy to get developed, the chemicals used at these places will erase the images off the film and appear as if the film is blank.
Nov 11, 2007 | Nikon N75 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
324 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
