How do you turn off and on
The following text is from:http://ipod.about.com/od/tes1/a/turn_off_nano.htm
Turning off the iPod nano
How do I turn off the iPod nano then, you may be asking? You let it, or make it, go to sleep.
The iPod doesn’t really work in terms of on and off. Instead it only deals in awake or asleep.
If you use your iPod for a minute or two and then set it aside,
you’ll see its screen start to dim, and then eventually go black
altogether. This is the iPod going to sleep. When an iPod is asleep, it
uses much less battery power than when the screen is lit up and the
music playing. By letting your iPod sleep you conserve your batteries
for later.
You can also force it to go to sleep by holding down the play/pause button for a few seconds.
Keeping Your iPod Asleep
If you press any button on your nano when it is asleep, the screen
will light up quickly and your iPod will be awake and ready to rock.
If you plan not to use your iPod for a while and want to store it,
you can make sure that you conserve battery power and keep your iPod
from playing a concert to the inside of your backpack by engaging the
hold switch.
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
