Question about Sharp 25K-S100 TV
Reprogramming my sharp 25k-s100 with universal remote
I had the remote working fine with the tv then the batteries or something went wrong and i can't remember the code to connect the remote with the tv...does anybody know what it would be for a rca universal remote....any help would be greatly appreciated...i belive it is a three digit code...thanks
Try 173
Posted on May 07, 2009
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
Cant sync my universal control what the code
Hello
You just try these codes with your tv. One aboung them will wake up your TV.
NB: Switch OFF and switch ON the Tv each time before a code is tested.
Three digit universal remote codes for Sharp are:-
027 /224 /324 /338 /631/ 637 /737 /825/004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp TV are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 22, 2010 | Sharp 25K-S100 TV
I have lost the remote how do I access the menue
Buy the Sony rm-v210 universal it will access the menu guaranteed
Dec 19, 2010 | Sharp 25K-S100 TV
Hi i have Sharp 25K-S100. how can i know whether it is HDTV or not. I dont have any manual. and I just want to buy one cable to connect my laptop to TV. Please adivse
Howdy, if it has a S-video input ( the round one with the pinholes) and your PC has S-video, then that will deal with the video. Sound runs seperately through either the red and white or the headphone jack at the tv end to the audio out port on the PC. Your TV does not likely have a VGA input, but if it does, then it is the same as the VGA standard monitor output on your PC. As yours is an older model, it may be tricky to get a decent picture from your PC.
Best regards, Farmerbear at FixYa.com
Sep 15, 2010 | Sharp 25K-S100 TV
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
How to switch to antenna usage without a remote for a sharp model 27K S100
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
Mar 22, 2009 | Sharp 27K-S100 TV
Universal remote
The bad thing is that not all universal remotes work for all functions of a tv. The thing is the factory remote. Order one at ROMOTES.COM. They sell them at a good price.
Oct 26, 2008 | Sharp 27K-S100 TV
I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Sep 11, 2007 | Sharp 27K-S100 TV
Sharp 25K-S100 TV Logo
428 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
