Question about Ricoh Aficio 3025 All-In-One Laser Printer
IR3025 I can't get my ir3025 to send emails. When i scan something to my address, I get a network connection error. Please help.
  • Ricoh Expert
  • 398 Answers
Make sure your Gateway address is correct
Posted on Jun 22, 2009
WHAT IS CANON ERROR CODE E000202-0002
Hi
My normal first step is to turn off any machine that exhibits a problem, and any other machinery to which it is connected eg a computer network etc. Leave it for about 10 minutes ad then restart it. This is sometimes sufficient to clear errors and reset the machine to an operating condition.
If this doesn't work I look elsewhere and in your case found a description of your error here:
Error Codes Canon iR3025 Code E202 0002
Also on this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page and you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 08, 2015 | Canon ImageRunner 3025 Black and White...
Print outs are coming blank in ir3025 ????
This might seem basic, but sometimes we overlook it when changing ink, or drums. Most come with a plastic seal at the bottom that you need to remove. Check if is still attached. Also, some laser printers need that a bar is slided to the opposite side (sometime back and forth) before installing the new cartridge.
After changing, try realigning, or notifying the system you changed the drum or the cartrigde; sometimes the problem is that is software locked. Hope this general guidelines help you.
Dec 22, 2014 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
I CANT SCAN MULTIPLE DOCUMENT AT A TIME
Buy acrobat pro. It allows you to do the actions you wish.
Mar 03, 2014 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
E000100-0001
press*#additional functions#. machine will display the following screen
service mode level 1 . from their choose copier. Go to adjust - clear- jam history-ok. Then err history - ok. Turn the machine off and on again. Your machine should wor fine.
Jan 31, 2013 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
Canon ir3025 error code e000024-0001
E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just needs a clean or replacing or the the cable ties to the toner sensor are to tight near the dev assembly just cut them off.
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3025
SOLVED Canon IR and IRC Printer Errors E000024 and E000025
See also page 2-107 (figure 640) here:
http://www.arbikas.com/view/locator/ir3045_3035_3025-pc.pdf
Nov 26, 2012 | Canon ImageRunner 3025 | IR3025 |
I need to set a Canon IR 3025 so that the Scan file type is PDF by default. at the moment it scans as TIF
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
Jan 24, 2011 | Canon ImageRunner 3025 Black and White...
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
IR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
May 06, 2010 | Canon ImageRunner 3025 Black and White...
Ricoh Aficio 3025 All-In-One Laser Printer Logo
335 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
