Question about Dell E153FP 15" LCD Monitor
Power button flashes green every 5 sec no display E173FPc dell
  • 558 Answers
Bad capacitors
Posted on Dec 09, 2008
Will a dell tft turn on with no source
Your monitor should turn on without a source and display the floating 'Dell - self-test Feature Check' message. If it does not, verify the power LED is on "GREEN" and indicating either power on / diagnostics mode or "Amber" power saving mode. If neither indication you have power problems. If these symptoms do not apply, shine a light on the sceen and see if there is a faint image. If this is true, you have backlight problems.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc Display Issue
Check if the cable connected to your monitor and video card is fix and secure.. Check also if the video card is properly seated in the motherboard.... Try to check using other computer if the video card is working..
If the test is all ok.. then the last option will be to check the backlight inverter of your monitor....To do this, you need to bring the monitor to a credible technician to have it replace..
much appreciated if you could rate this help..thanks..
May 24, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Wont display anything, green light on power button keeps flashing
The flashing light on the Dell E173 series indicates a failure in the power supply board. This series has several versions on the board so you will need to know the exact model, it is listed on the label at the bottom of the back cover. The versions are E173FPc, E173FPb and E173FPf. We have repair instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ that cover each version on the unit. The repairs will require replacing a few pars that will need to be soldered.
Buddy
Corporate Computer
www.ccl-la.com
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Dell flat screen monitor E173FPc I put the power on and it comes on but the display turns off after 2 secs while the power light is still on
godiac, What does the flashlight trick tell you? I suspect that the "switch-mode-power-supply" has detected a fault with itself or the CCFL "inverter supply" and is now in partial of full shutdown trying to save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. Learn flashlight trick for gross status check of unit's SMPS! It might be possible to repair(refurbish) unit for $8 on a DIY quest! If no warranty available or no possible DELL cash+old for refurbed unit then look into doing DIY fix. Follow leads in other responses in my FIXYA profile to help you make decision. 12fixlouie aka louie12fix
Dec 31, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc
That is a slightly different power supply board if it is the one I am thinking of.l It is similar in style but there is a 1000mf 16v capacitor that once you replace it it will work.
Mar 22, 2008 | Dell E173FP 17" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
140 people viewed this question
Alun Cox
