Question about Kodak EasyShare M1033 - black Digital Camera
Downloading to computer
Usb plugged into camera & computer, how do I start the download process?
  • amahon Dec 26, 2008
    My xp pc will not read the camera USB, nor will the USB connection on the TV and by putting the 8gb card into card reader on PC will not detect it either. The card was formatted in hte camera prior to use.
    When I hook the USB to the pc, the camera screen goes blank, but no drive shows up on the pc. I have no such problem with my other cameras.
  • leo8888 Feb 24, 2009
    Spent an hour with a kodak support tech just trying to get the connection software to install without an error. Used the "cleanup tool" from kodak that is supposed to remove all traces of old kodak software. I finally had to manually remove all traces of kodak software from the registry and scan the C: drive for kodak files and folders to delete and was then able to install the connection software without errors. my winxp pc now detects the camera and installed the drivers but it still will not transfer pictures. It shows up in device manager as a USB Hub instead of an Imaging Device like it should. Kodak support emailed me with more things to try like connecting to a different computer or trying a different cable, neither of which helps resolve the actual issue.
  • 76 Answers
If the operating system is Windows XP or Vista, it should automatically detect the USB device and open the drive for you. Else you will have to install the software that came in the CD along with the camera..which is used to manage files or sync files between your camera and PC..
Hope this helps..do feel free to ask any questions. :)
Posted on Dec 09, 2008
Nikon COOLPIX L20 Digital Camera + lost connection message
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 22, 2012 | Nikon COOLPIX L20 Digital Camera
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Can not download pictures from my camera. When I hook up usb cable and turn on computer all that is on the camera lcd screen is the usb symbol with the letters usb. I get an error when finepix software...
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
    Nov 21, 2010 | Fuji FinePix S1000FD Digital Camera
    Computer all of a sudden won't recognize my camera. Says device not recognized. When I plug into USB port my camera starts flipping back and forth showing processing and then showing the screen you seen...
    Have you considered NOT connecting the camera to the computer?
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
    Aug 09, 2010 | Kodak EasyShare M1033 Digital Camera
    Can I download pictures to a computer with Windows 7 with my FinePix Z10fd digital camera?Is it compatible? I get an error message when I start the download process. (I had no trouble on my XP computer).
    It doesn't matter to the camera what operating system you have on your computer.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
    May 18, 2010 | Fuji FinePix Z10fd Digital Camera
    Why can't import my pictures into the computer?
    Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
    Transferring pictures/videos with the USB cable
    Turn off the camera.
    2 Plug the labeled end of the USB cable into the USB port on your computer.
    3 Plug the other end of the USB cable into the USB port on the camera.
    4 Turn on the camera.
    Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
    If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
    Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
    Problem in downloading picture from DSCP100 sony digicam
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
    Jun 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
    Black screen HELP!!!!!!
    Try this,
    Before plugging into USB cord go into menu on the camera. Then scroll down to setup press, then scroll down to USB mode. Press OKAY, then click on PTP and OKAY button. Now exit out by pressing menu button until back to the LIVE CAMERA phase.
    Now plug in USB, CONNECT TO COMPUTER & should read PROCESSING...
    Wait a few minutes (camera is very slow). Watch computer screen as a small bos should pop up which reads
    AUTO PLAY now scroll down to
    DEVICE OPTIONS - IMPORT PICTURES USING WINDOWS
    Click on this
    Now photo's should start downloading
    Sep 27, 2008 | Sanyo Xacti VPC-S60 Digital Camera
    EOS 400D Digital Camera Software
    Hi
    If you bought your camera (400D) new it would have come with RAW conversion software on a disk. You can start by installing this. To get the photos off the camera you should be able to plug it in vis the USB cable that came with it. The better way would be to buy a card reader. This is a lot quicker, save on battery wear and tear, or save you plugging in the power.
    Alternative software would be to buy Adobe Photoshop Elements for the RAW processing. This is a good start for most people.
    Regards
    Jul 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
    Windows will not cecognize my camera
    I don't have a solution, only know that my A85 was repaired twice in two years and now has the same problem for the third time.
    Oct 19, 2007 | Cameras
    Kodak EasyShare M1033 - black Digital Camera Logo
    157 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
