Question about Xerox Phaser 8500/DN Printer
Data path failure 16.4 xerox 8500
Hi i was wondering if you can help with that, every time i print something the page come out almost blank and reported a hardware failure data path failure (16.4). let me know thanks.
  • carverron May 04, 2009
    My front panel display is blank and the printed startup sheet says front panel data path failure (16.4)
  • 28 Answers
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install - eeven though it is out of warranty and at no charge
Posted on Aug 06, 2009
  • 31 Answers
Shaun Rigby is right. This is a known problems with this model of phaser. Thanks to Shaun for posting this!!!
Posted on Nov 16, 2009
  • 23 Answers
Control Panel data path failure, bad data
returned.
16.4
Unplug all wiring and/or cables to the electronics module and reseat.
If that does not work you will need to get an electronics module.
Posted on Dec 23, 2008
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
I get a print out from start up which says "Hardware Failure: Front Panel Data path failure (16.4). What is that?
Here's a link to the error codes, note the 8550 codes are on the right side. (See POST codes.)
16.4 is a soft error code, i.e. doesn't prevent your printer from starting up, but generates a printed report. "Control panel data path failure, bad data returned." See page 4 for instructions recommended in this case.
You can access a remote dignostic tool from Xerox for your machine here., and here are support center instructions.
Here is the home support page for your model.
There may be firmware updates available for your printer that could help to correct some issues.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Xerox Phaser 8550DX Laser Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8500 excessive ink use
One of the reasons this could be happening is because you are using non-xerox ink so your print head needs to clean it out much more often. Be careful using other ink as this can destroy the machines printhead which is more expensive then the machine itself to replace. What you could try is installing the new printhead firmware, it might help! Follow the link below and good luck!
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8500_8550&country=United%20States&language=en
Niallbt
Jan 09, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
The display panel needs to be replaced. The part number is 802K93650. We sell them for $160 plus shipping. Our number is 574-243-1176 if we can help.
Jul 23, 2008 | Xerox Phaser 8500/DN Printer
Unreadable characters
check if the file is not currupted.
and the printer is set for RAW printing, probably dont have enough memory, to print the document
try printing like only 10 pages at a time to see if the last 10 print
if it does might want to invest some money in some printer memory
Jul 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500
Most likely your driver is corrupted. I would go to xerox.com and download a newer version and install a new driver.
Power off and power on your printer also.
May 15, 2008 | Xerox Phaser 8500/DN Printer
The front panel shows nothing
When our control panel went blank last month, Xerox did not offer a free replacement because our printer was out of warranty. Consequently, we ordered one from SparePartsWarehouse.com at the best price we could find - $104.87 plus shipping. The part number for our 8550dp is 848K06551, but these are the compatible part numbers for the "Xerox 8500 Control Panel & Bezel": Compatible Part Numbers: 848K06551, 101E28730, 101E28731, 802K93650, 802K93651, 848K06550, 848K06552. It is easy to replace, instructions are on the Xerox website at http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enus.html
Hope this info helps someone, and thank you FixYa for this forum.
Aug 30, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
2,020 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
