Question about Magic Chef 31000 Gas Kitchen Range
Maytag/Magic Chef CGR1110ADW gas range
Burners work fine. Oven will not come on. There has been a power failure. My User's Guide does not tell me if the oven is Pilot or Pilotless Ignition. I have tried lighting pilot as directed in User's Guide to no avail.
Thanks
  • 1 more comment
  • backbone Dec 15, 2008
    I turn the oven on and it will reach a lower temperature than what I want it to be. Along with it not reaching the temperature setting, I have a fairly strong odor of natural gas. Is the gas line clogged? Top four burners function fine, it's the oven that will not heat up.
  • Anonymous Mar 15, 2009
    stove burners work. The have gas pilots that are on. The oven won't light. The oven is pilotless.
  • how old is your stove?new stoves do not have gas pilots.
  • Magic Chef Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
adfaf
Posted on Sep 30, 2010
Our Magic Chef oven just began making a whirring noise and the clock stopped functioning properly at the same time.
Hi Peggy Freeman,
I suppose that it is a Maytag Magic Chef.
From your description my conclusion is an electrical fault on the clock.
You have to open the cooker and remove the connection to the clock.
BE CAREFULLY
Always insulate the connector, as it is mains grid.
When it is indeed the clok, the noise will stop, but you an not use the clock anymore.
Kind regards, Dik
Here you find a PDF of the Maytag Magic Chef:
https://www.repairclinic.com/UserManual/b8e1b97795884ea59496a9eaf1a93883/Magic-Chef-Range-Stove-Oven-Repair-Manual-CGL1100ADQ-CGL1100ADW-CLL1101ADW.pdf
Feb 08, 2018 | Kitchen Ranges
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
After a recent power interruption the Electronic
These electronic controls are very sensitive to power surges. I am afraid your control is now bad and must be replaced.
There are no fuses or reset buttons.
Nov 13, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Magic chef gas oven will not turn on
F1 means, defective touch pad or control.
Jan 09, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
432 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
