SOURCE: I have a whirlpool catalyst
what is your model # i looked at the manual there is no F4 code they only go up to F3 if you post your email i will send you the service guide
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
SOURCE: HOW CAN I GET A LIST OF ERROR CODE FOR WHIRLPOOL
there is a tech sheet in the console with diagnostics and error codes,make sure you put it back,if you call someone in to repair it in the future and thats gone they might not be able to help you,also there's a recall on your machine,they're having alot of problems with the control board,i've told other people about this and they wrote back saying that whirlpool is fixing their washer for free whirlpool F1 code - Appliance Repair Forum
SOURCE: I have a gold catalyst
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it.
Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=3020600
SOURCE: My WHIRLPOOL GSX9885JQ0 Top Load Washer suddenly
Open the cabinet and look at the suspension springs holding the tub. Here is a video to show you how to open the cabinet.
