Question about RCA WSP150 Main / Stereo Speaker
Need assistance on where to connect WSP 150 to Sony Trinitron TV
None of the audio plugs on the back on the TV seem to be the correct size
  • 492 Answers
Go to radio shack as them for a stereo rca to mini plug adapter.
Posted on Dec 09, 2008
Has audio, but why no video?
Please describe how you TV is setup and connected to devices.
Check to make sure you have the correct input selected.
Also, check to make sure you have correctly connected the video cables and that you don't have bad video cables.
Another thing to try is unplug the TV for 30 seconds.
Prepare to observe the Standby LED on the lower front of the TV.
Plug the TV back in and see if the Standby LED blinks, counting the number of blinks. These blinks are the self-diagnostic codes.
Post your findings here.
Mar 31, 2016 | Sony FD Trinitron WEGA KD-27FS170 TV
Connect roku tv to Sony Trinitron
The roku has a cable that you can connect to those 3 plugs. Take the HDMI cable back and give the salesman a piece of your mind. Once your roku is set up you can watch much more than NetFlix.
Jan 23, 2014 | Audio Players & Recorders
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
I have a Sony Trinitron model kv-a2921b. The TV
HELLO MIKE
I don't think your TV is totalled! It's more than possible that a speaker connection on the main board has come adrift and just needs pushing back in. Check connections on the speakers themselves and when you trace back the cables there will one or two push in connectors.
It may be a good idea to get the speaker connection plugs checked and resoldered. It is also possible that the fall could have jolted the audio IC and this should be checked for dry joints or cracked print on the board too.
Hope this helps (:-)
Oct 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Connecting DVD player to Sony trinitron KV-20DVM30
Your description of your set sound like it is a mono set. You should be able to plug in the yellow and the white connectors and get sound out of both speakers. On most sets, if there is audio on the left (white) wire it will produce sound from both speakers.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Sony KV-20VM30 20 in. Combo
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there?...
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
Feb 21, 2009 | Sony Audio Players & Recorders
Sony Trinitron KV-19TS20 Screen displays purple static or awful image.
This unit needs a tuner. A new one from Sony will run over $70, so I doubt that it is worth it. It is possible that poor ground connections could cause something like this, but the symptoms seem a bit too severe. I think it is time to invest in a newer set.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Jan 27, 2008 | Panasonic SC-HT680 System
RCA WSP150 Main / Stereo Speaker Logo
141 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
