Question about Sony VAIO RB30C (VGCRB30) PC Desktop
Windows problem? i have a "File minint\system32\biosinfo.inf" with an error code of 4128 popping up on me. i cant restart from safe mode and have tried through awardbios and tried to restore to factory settings. no luck. any suggestions?
  • Anonymous Feb 10, 2009
    If I reinstall the OS will I loose all of my data?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Is it a maxtor hard drive in the PC?
  • 66 Answers
Just reinstall your Oeratuing System
Posted on Jan 06, 2009
Installing Windows 7 from a flash drive. " $WIN_NT$.BT\biosinfo.inf could not be loaded. The error code is 14 ". Pretty sure it's not an error on the flash drive seeing as how I have used it succe
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Hope this helps.
Nov 17, 2012 | Dell Computers & Internet
How to fix \minint\system32\kdcom file cannot load error 4 Emachine
Download this file to your computer and burn it to a CD:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
If you don't have an app that can easily burn .iso files to a CD then get this awesome little FREE app and install it:
http://www.majorgeeks.com/downloadget.php?id=4870&file=9&evp=0636b68877cb69b15faa3374cb1dcd89
The Bootable CD you burn should fix your computer. It's really easy to use. Just follow the instructions from page 15 to page 33 in this pdf:
http://support.kaspersky.com/downloads/guides/kasp10.0_rescuedisk_en.pdf
You basically want to update the virus definitions and select all of the checkable boxes to scan and run the scan and then allow it to delete or quarantine the bad files.
Sep 01, 2012 | E-Machines eMachines Desktop PC
C:\minint\system32\restore.log mising
Restore points are located in C:/Windows/system32/restore.
You have an unusual error message which talks about C:/minint folder. Seems like this is a virus issue. It would be better if you run virus scan for your computer.
Also run a system utility software RegInOut to refresh your PC.
Dec 13, 2011 | Computers & Internet
OS won't start on Sony VGC-RB60G
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
Oct 06, 2009 | Sony VAIO RB60G (VGCRB60G) PC Desktop
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Cant get past error even tryed to repair windows or how can i install reinstall
Try booting into safe mode by pressing F8 when boot up starts. Choose safe mode. When it's booted up, right click on "my Computer" and choose properties. Click on advanced and choose the advanced tab. Go to performance and change the settings of Virtual Memory to what Windows Recommends.Restart.
May 29, 2009 | Gateway Essential 400 PC Desktop
Clevo 900K, Crash: c\windows\system32\config\system - file is missing or corrupt. Insert original setup CD and press r for repair. I don't have original CD. System won't restart even in safe mode or d
to setup a new windows installation or repair an old one you do need an installation cd, for it, no other way i am afraid,
ask for safecopies from a friend, maybe
Apr 21, 2009 | Computers & Internet
I recently attempted to do a system recovery and this is what i got, (file\minit\system32\biosinfo.inf) could not be loaded, error code is 14 set up cannot continue , also my internet explorer will not...
if that what you did and got that kind of error... try boot selection and select.. Last Known Good Configuration.. by Pressing F8 while turning on the computer, there is a selection you need to select your primary drive, where your windows installation installed. select the drive and then select Last known good configuration or safe mode if the first selection won't work.. when you select safe mode and it start windows properly do the System Restore in the safe mode if you want it.TY
HOPE I CAN HELP
Dec 05, 2008 | Computers & Internet
Blue colour background saying it is the stop error screen.
The fix from Microsoft's website:
  10. Click OK.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
Bios could not be loaded error code
Sure , you need to change the battery in your motherboard. Often it looks like a silver coin. What happens is that your bios setting are reset to default each time you restart PC, before updating bios (that is the solution from hp that you are trying), change the battery.
regards
Mar 04, 2008 | HP Compaq d530 CMT PC Desktop
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
158 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
laikexpert
laikexpert
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
