Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
Line across top of screen
A line has appeared at the very top of my sony tv screen. The line is straight and is rainbow colours. It will appear when the tv is on video 1, 2, 3, or 4. What could have caused this line to appear and how can it be fixed please?
  • RSchoon Nov 20, 2007
    i have the same exact problem...however the line only shows up when there is very little white in the image...can this be fixed?
    also referring to the solution above, how do i adjust the vertical alignment?
  • Kevin Reaver
    Kevin Reaver Jan 26, 2009
    The line appears and disappears, but it never changes position or size. I'll check to see if it has anything to do with the ammount of "White" on the screen as described above.
    President:
  • 1,284 Answers
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
Posted on Feb 27, 2007
Sony KDL43W800C 3D LED TV coloured vertical lines on the screen.
The panel is Faulty
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 24, 2016 | Sony Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
I have a Sony Bravia LCD Flat TV. About 2 months ago small horizontal lines appeared. They are rainbow in color. Now many more have appeared...it is getting much worse. The plastic front is actually...
Sounds like the TV may be hooked up to a source with too much voltage, or getting overpowered in some other way. This is a safety hazard; if it's hot enough to melt the screen cover, it's hot enough to explode without warning. This isn't something you should try to fix yourself; call it in for servicing if you can. In the meantime, you should keep it unplugged.
Jan 29, 2018 | Sony BRAVIA KDL52XBR2 Television
Blue background with "rainbow" like
Check the info from this link to see it it applies to the rainbow lines from your TV.
Jan 04, 2011 | Sony KP-65WS500 65" Rear Projection...
I have a GVA tv which when I turned it on this morning has now got a sort of circular rainbow on it, the people in centre of screen appear green, then it's like a blue circle filling most of screen, then...
your positor has failed you can change it your self if you have a soldering iron you can find parts on charles hyde web site and you will need model mumber of tv they are not expensive £5 not hard to replace but if you take tv to shop you are looking at a bill of about £50 - £60
Nov 27, 2009 | Televison & Video
Colour lines on samsung tv top side concave
  • Unplug your TV.
  • Leave it unplugged for a minute or two.
  • Plug the TV back in and turn it on.
  • Dec 06, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
    Appearing rainbow colour for sometime and getting off.
    There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
    Please inspect convergence board and resold dry solder joints.
    Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
    Rainbow colours appear on the screen after it fell over
    Hey there well what i think happend is that the convergance has been modified and some parts has moved inside the TV. There's lots of posts in this website about this problem so just search for convergance. also check this link it will exlain you exactly how to deal with it http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html Let me know if you need more help :) Tom
    Jun 26, 2007 | Daewoo DTQ-27S2FC 27" TV
    Open Questions:
    I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
    Jan 19, 2019 | Samsung Televison & Video
    See all Sony FD Trinitron WEGA KV-32FS16 32" TV Questions
    Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
    190 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
