Question about Sony CDX-M8800 CD Player
Main Display Window
The main display window on my unit quit working all the other functions and internal display work. I have checked connections tried resetting unit but nothing any suggestions of what it could be would be appreciated?
    Sergeant:
    Champion:
  • 326 Answers
Hello Gully, the flat cable between the front panel and the radio. If you want I can give you the part number but the replacement of this cable is not simple. Best regards, Arpi
Posted on Feb 27, 2007
SOURCE:
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
Hi, my display is not woking on my JVC PC 55. Although, the stereo DOES WORK !! It doesn't even light up. Why is tghis? Thanks in advance, Joel
Possible failure of the display unit or the power to the display unit. This is irrespective of the functioning of the set as the main processor is working and the display operates on the sub-processor.
remove panel and check the flexible strip and the voltage to the unit to confirm.
Mar 13, 2011 | Audio Players & Recorders
No picture on the window
Possible that the flexible strip connection had been damaged and so the display does not seem to get the connection correct.
it will be necessary that you have the ability to open the display and camcorder main covers to see that the status of the connection wire.
if the strip seems to be good with continuity tested, then the fault can be failure of the power to the display- check power supply or the failure of the LCD display unit.
Jan 17, 2011 | Canon DC40 DVD Camcorder
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
No picture on 42" Vizio LSD.
First update the display adapter drivers
After that, right click on the desktop
If u're using vista, click on personalize and on the next window click on display settings, and then u'd come across another window which would have a drop down menu... click on that and select the 42" monitor, and check make this my main display ..
If u're using Windows 7, click on change screen resolution, and then u'd come across a big window with lots of information, window which would have a drop down menu... click on that and select the 42" monitor, and check make this my main display ..
Nov 22, 2009 | Vizio VW42LF 42 in. LCD HDTV
Operation buttons and sub display are failing
go to ebay and type in the model number of the unit and it will bring up some part that can fix the problem. i had the same problem and i just ordered the part. its actually a ribbon connector. im sure you just open up the radio and take the old one out and connect the new one up. this seems to be a common problem with this unit. the ribbon just starts to tear, and as it tears, you will start to lose functions on the stereo. i happen to like this stereo, so i decided to repair it. good luck with yours.
david
May 31, 2009 | Sony CDX-M630 CD Player
Infinity radio - display window not functioning
inside the radio is a miniature bulb that back-lights the display, this is true of all radio's, in fact they all use the same tiny bulb, these do burn out from time to time, u will need to remove the radio/CD unit and then pull the top cover off, inside just behind the display u will find a small twist in socket that contains the bulb, u can buy this bulb at any full service auto part's store for about $2
Feb 16, 2009 | 2002 Mitsubishi Eclipse
I have a CDX-M8815X unit only works with remote commander
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from pacparts.com or sony.com.
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
Nov 30, 2008 | Sony CDX-M8815X CD/Receiver/MP3 System
IC-R8500--Display is flashing continuously--no receive
First check the tape cables from Conv Unit and Rf unit to main unit.
Second find if the PLL ICs lock (MC145190) check voltage at pin 2 (LO) ~4,5Vdc in PLL Unit.
Third find If the (PQ30RV31) voltage ADJ in main works.
Nov 01, 2007 | Icom IC-R8500 Base Scanner
Front display panel has power, but won't open
its usually the flexible pcb that connects the fascia to the main board thats snapped and therefore needs replacing
Aug 28, 2007 | Sony CDX-M800 CD Player
Sony CDX-M8800 CD Player Logo
99 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
