Problem connectiong to DHCP server and acquiring a network address from router. using netgear router and linksys adapter. ICS
  • Mark Robinson May 11, 2010
    when you view available wireless networks are you able to connect to your preferred ie netgear router ? if so try resetting the router and let me know what happens then
  • 69 Answers
Hi There,
Your router, is it wireless?... anyway take a look at the security settings. I think that you have setup up your security setting with a wep key. If so than you need to enter a pass work into your computer to access the router for it to assign a IP address.
Let me know if you need more help.
Regards,
Philip
Posted on Dec 09, 2008
Cannot connect NetGear WN3000RP with wireless
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference TechSpot.com for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router Passwords.com for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
b>
Dec 05, 2012 | NetGear Universal WiFi Range Extender...
How do i split out multiple static ip's
You need to attach a DHCP-server to the hub/switch, and configure that DHCP-server to "reserve" a specific IP-address for the MAC-address for the network adapter inside each of the computers that is to receive a "static" IP-address.
For a DHCP-server, you can connect a "cross-over" Ethernet cable from one of the switch-ports to one of the LAN-ports on any "home" wired router. That "home/SOHO" router will become the DHCP-server for all the computers connected to the switch.
Nov 19, 2012 | Linksys Computers & Internet
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Netopia 3d reach will not acquire ip address
Make sure that DHCP is turned on on the router. If it is, reset your router and try it without wep to check that it is working.
May 16, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Xbox 360
Either the network connection between the 360 and router is not working correctly, or your router is not configured properly for DHCP.
DHCP (Dynamic Host Configuration Protocol) is a protocol that automatically assigns a network address (and some other settings) to your computer....or Xbox in this case. It works like this....when your Xbox connects to the network, it sends out a broadcast packet on the network that looks for a DHCP server. If a DHCP server is present, it responds. Next the Xbox requests its network address and other settings from the DHCP server. Your WGR614 router has a DHCP server function built in, but it may not be enabled. Try reconfiguring the router using the Netgear "Smart Wizard" installation CD and be sure to enable the DHCP capability, if asked.
Jan 10, 2008 | NetGear WGR614 Wireless Router
Acquiring network address
From the PC you are trying to connect to your wireless router LAN there are two possible causes of these problem.
1. No DHCP Server Available.
2. You are using MAC Filters and the MAC is not defined in the router configuration.
Please verify this and you can easily get through it.
DHCP can be configured over your wireless router also incase you don't have DHCP Servers in your LAN / WAN. Other wise you can go for manual IP addresses.
Jan 04, 2008 | Linksys WRT300N Wireless Router
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
