Question about RCA OPAL M4001 MP3 Player
Installing brookstone photo viewer.... program hangs up on "initializing" following installation.
  • Anonymous Dec 30, 2008
    Program gets hung up on initiallizing program.
You might try connecting the keychain first and making sure it turns on upon connecting to your PC via the USB cable.
my problem is the photo viewer software that came with it doesn't find any JPG images to put on the keychain...it crashes everytime i click a folder to browse and i've removed and re-installed it twice now. what a piece of ****.
Posted on Dec 21, 2008
  • 04TL
    04TL Dec 21, 2008
    so i solved my own problem...
    basically the original software would crash whenever finding a directory with JPG files in them...this software, which is pretty much the same thing, actually works...
    http://taoelectronics.com/downloads/TAO%...
I need to download photo viewer installer
Hi
Download the picasa its the best photo viewer and editing and sharing
download load link here----
http://picasa.google.com/
May 16, 2011 | Computers & Internet
I have problem opening the photos from a friend in picassa
Hello
This problem can be resolved by opening the "Control panel" and selecting "All Profiles" under the "Color Management" file. Add the "sRGBIEC61966-2.1" profile to the "ICC Profiles."
Make sure that the digital photo file that you're trying to access isn't open or in use by another program on your computer. Oftentimes, two programs can't access the data contained within a file at the same time. If your photo is already open in another program, for example, you wouldn't be able to open it in your digital photo viewer/file manager.
Make sure that the file format of the digital file you're trying to open will actually work with the file manager you're trying to use. Not all programs are going to be able to open every file type. There are dozens of different photo files types in existence. Look at the photo file's extension and then look in the instruction manual that came with your file manager to determine if that program can read that particular type of file.
Reinstall your digital photo viewer file manager utility. If you purchased your program in a store, insert the CD-ROM you used to originally install it into your computer and select "Repair" when its setup program automatically opens. If you installed your digital photo viewer file manager utility from a computer file you obtained on the Internet, execute the original installation file and select "Repair" to reinstall your program on your computer.
Make sure you have the latest version of your digital photo viewer file manager. Programs are often updated by their original manufacturers to fix errors and issues that users have been known to have. Open your program and click on the "Help" tab. Look for an option that reads something like "Update" or "Check for Updates" and select it to connect to the Internet and make sure that you have the latest version of the program installed on your machine.
Nov 05, 2010 | Computers & Internet
When I try to install the coby dp 151 it says: cant find photoviewer or program that owns it. the program will exit. ?? confused
The error you describe, is also mentioned in the Setup Guide for the DP151.
When you connect the Key Chain to the USB port of your computer, on the Key Chain will prompt the message to select: USB charge or USB update.
For proper function of the Chain Key:
0) Before connecting the Chain Key, have the Photo Viewer software installed:
You need adminstrator rights to perform installation of programs.
Install the photo viewer from the CD or download this program
from the Coby support site:
> enter cobyusa.com in the address bar of internet explorer
> enter DP151 in the Product Search bar
now all support for the Chain Key will show
> run the DP151_PhotoViewer zip file directly or save the zip file onto your computer, unzip and run the setup.exe file later
1) Connect the Chain Key and Select USB update on the Chain Key.
Again, to be able to update, you need adminstrator rights.
2) Run the Photo Viewer on the computer.
Aug 15, 2010 | Computers & Internet
I have not used my Photo Viewer for a few months. Was working ok. But now Software would not respond when I plugged keychain in. Tried many times. Uninstalled PhotoViewer Software. Re installed same....
The program is corrupt. Uninstall it, delete all remaining files and folders, run a registry cleaner, defragment, download a new installer and install it again but in a different location.
Or you could just install a much better photo viewer   http://www.irfanview.com/
Aug 03, 2010 | Computers & Internet
My photo's are showing up as a vertical line in my viewer program. when opened in paint they are showing up as the full photo but everywhere else are just that vertical line... however when opened in...
hello ! try this get Another photo viewer program and install it on your machine eg adobe photoshop,nero photo viewer .
the thing is your pc has no right program for this kind of photo resolution .
Jul 22, 2009 | HP Compaq Presario F500 F700 and G6000...
Can't download program from photo viewer software 2.3c to my computer
Here is link for both windows and mac. Haven't tried it as of yet though.
http://stevenhansen.info/weblog/electronics/brookstone-digital-photo-wallet-ovo-photo-viewer-22
Apr 01, 2009 | SmartParts (DC-MM306ATG-VP) Digital Photo...
Photo viewer program stuck on ''initializing''
you might try connecting the keychain first and making sure it turns on upon connecting to your PC via the USB cable.
Dec 09, 2008 | Computers & Internet
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Panasonic Lumix Simple Viewer & Photofun Studio Viewer software
If you google your camera model, you will find a location to download software for this camera. The Panasonic Support site is a good starting place..
Kodak has a free photo viewing an touchup software downloadable so you will use their printing service. Another is Picaso by Adobe. Both of these are easier and better than those supplied with camersa. Even Microsoft XP or Vista computer come with a good viewer. Go to Start/Programs/Microsoft Viewer(or some such).
Nov 01, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Zire 31. My instalation disk does not include fasilities to download the photo software i need to transfer my photos to handheld. Where can i download/obtain i think its called Palm Photo program
The program is installed in rom, look for program "Media", I suggest you to install for a better freeware program to manage photos on your handheld, like grxview lite (or the shareware resco viewer)
Jun 26, 2008 | Palm Computers & Internet
RCA OPAL M4001 MP3 Player Logo
2,735 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
