Question about Kenmore 63942 Dryer
Dryer wont turn
I have the 80 series kenmore dryer and the drum has stopped spinning. The dryer still heats but will not 'tumble'. From the back of the dryer I can see the broken belt? How do I go about replacing the belt and is it worth it?
  • calsbell Dec 15, 2008
    VTD00 washer dryer - Is heating up but the drum is not turning. It is about a year old.
  • Anonymous Mar 22, 2014
    dryer drum won't spin
    Scholar:
  • 63 Answers
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Posted on Dec 09, 2008
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Does a Kenmore Series 80 have a drum belt
Yes, it has a drum belt. If you can't see the belt wrapped around the exterior of the drum, more than likely it has broken and is wrapped around the drive motor shaft, or lying on the interior cabinet bottom. If the dryer still heats, but the drum does not turn, this is probably why. Please post back with your model number (located on a nameplate around the door opening) and I can tell you how to access it and/or replace it.
Posted on Dec 29, 2009
I have Kenmore 80 series dryer. The drum is not tumbling, but the belt is fine. It heats up and the vent still blows. Help!
Does it sound like the motor is starting? If the belt is good, but the drum won't spin, it sounds like the motor is gone or the drum has seized.
Feb 20, 2015 | Kenmore Dryers
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
I have a kenmore 80 series dryer that heats up and will not tumble. The model # is 66822692. Can you please help?
Open the back panel to access the belt. There is a motor to make the drum tumble by the belt. If the belt is not intact then motor turns but not the drum. If the belt is in good place then motor is not working. Check out the continuity of the motor, if there is then there is a problem with the circuitry. If there is not continuity from the motor terminals then the motor is burnt.
Dec 28, 2009 | Dryers
Kenmore 80 series HD+ dryer will not heat. dryer runs and tumbles fine just no heat
Check thermal fuse behind the dryer by opening the back cover.Fuse is on the air duct.
Jun 18, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 63942 Dryer Logo
346 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
