Question about NEC MobilePro 900c Pocket PC
Nec Mobilepro 900c
Hey I just bought a used 900c mobilepro 900c ihave a lan connector and wifi card but it doesnt connect ot the internet with either and the device is not recognized by active sync on the computer.The machine though seems to work perfectly fine i think the fault is with me like I am not setting it up properly.I bought this on ebay and it looks practically new.
  • 21 Answers
Right clik my computer,go to properties,click on properties,click on hardware devices you will see the list of all the hardware components installed on your computer,check to see if your network adapter is installed,if not installed you will see a yellow balloon attached to the adapter icon,then try and install the device.if the device is installedbut you can't browse,i think that has to do with you internet configuration.try using the a unique computer name and the correct workgroup name,good luck.
Posted on Feb 27, 2007
SOURCE:
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
NEC mobile pro 900c
Will need to know the brand of your wireless card as it probably needs the driver installed. Hopefully can point you to driver download once know type, version, etc. of wireless card.
Dec 17, 2007 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c softeare
maybe is because processor ou version of windows ce
Aug 22, 2007 | NEC MobilePro 900c Pocket PC
Mobilepro 900c Ethernet Card
I use the AVAYA wireless card. It needs to be wireless B. Dowload the driver for it when you sync. Then it should work.
Aug 21, 2007 | NEC MobilePro 900c Pocket PC
WINDOWS CE PROBLEMS
Perhaps the programs you are trying to install are designed to run on your desktop PC and use activesync to transfer to the PDA..?
Aug 19, 2007 | NEC MobilePro 900c Pocket PC
Looking for software and I have a I.E. question
Olive Tree has a Bible program that runs fine on the 900c.
tmwsr3@yahoo.com
Aug 18, 2007 | NEC MobilePro 900c Pocket PC
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
