Question about Whirlpool Dryers
Only half of the heating element works
Hello,i have a 2006 wirlpool dryer model number wed5900swo and the dryer takes two cycles to dry my clothes.i replaced the heating element,and still the same problem,only half of the heating coils work.can you help me?
  • BRIAN SURPRENANT Dec 09, 2008
    i pulled the heating element out and ran the dryer and only half of the coils are working
    i also checked the vent and hose and its clear
    President:
  • Whirlpool Master
  • 2,651 Answers
i looked up your model andfound it to need part number 3401338, this is the heater, i cannot see howe only 1/2 of the coil is going to light, its either on and all lights or its gone bad in which case its never gonna glow, its one filament like a lightbulb as long as the filament is good its alll good. too long to dry or extendedd dry times is most likely an issue with a blocked/clogged vent hose
Posted on Dec 09, 2008
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 19, 2012 | Kenmore Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
The heating element in my Kenmore dryer, model number 110.63032101, does not fully heat up sometimes. With the setting on cotton/high the element will sometimes be fully illuminated and sometimes only...
no,that's how they run,if your clothes are drying and the dryer is cycling on and off,leave it alone,if the clothes are taking a long time to dry clean out the duct that the lint filter slides into and blow out the vent line with a leaf blower if it's a long run
Oct 12, 2010 | Kenmore Dryers
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Hello my Kenmore Dryer is working fine although taking alot longer to dry the clothes. I took everything apart and clean it, no vent blockage, and great air circulation through dryer. I was wondering; is...
THE ELEMENT CYCLES. NO IT DOESN'T STAY ON THE WHOLE TIME, BUT IT SHOULD BE ON FOR MORE THAN A BRIEF SECONDS TOO. POST ME THE MODEL NUMBER FOUND SOMWHERE AROUND THE DOOR AND I'LL HELP FURTHER. THERE ARE THERMOSTAT/S HIGH-LIMIT SHUT OFF SWITCHES AND IF THEY ARE NOT FUNCTIONING PROPERLY IT WILL CAUSE DRYING TIME PROBLEMS
Apr 11, 2009 | Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
