Question about Whirlpool GEQ9800P Electric Dryer
Dryer takes 3-4 cycles to dry clothes
We checked everything, ducts, electrical and everything is fine but it still takes 3-4 cycles to dry 4 towels.... could the fact that we live at a higher altitude be part of the problem. Have even tried running them through the spin cycle of the washer twice prior to putting in the dryer.
Check if the outdoor vent is clogged by lint. Also, check the tube going from the dryer to the wall. If the air outlet is blocked, the dryer takes very long. I had the same problem.
Posted on Jan 11, 2009
    Problem Solver:
  • 14 Answers
Hi first are you sure your heating element is good and working is the dryer getting hot in side when you open door to check clothes.if they are and you are sure the duct work is clear and no clogs, you might try this I have heard this from other people take your lint filter out and wash good with hot soapy water they say that after so long using dryer sheets this filter can get a invisible coating on it.
Hold the filter under water and see if it will holds water I know it sounds crazy but I have heard it from more than one source.
Posted on Dec 09, 2008
The dryer is not get hot. It take 2or 3 times ti dry the clothes
You might want to take a flashlight and check the vent and duct from the outside in. Lint will build up in the duct and vent over time. When you turn on the dryer with wet clothes in it, the lint will get damp quickly and it will dry out quickly too which make the dryer cycle shorter but not long enough to dry the clothes. Clean the vent and duct regularly and that should take care of your problem. You can buy brushes for doing this and they are not costly.
Jan 04, 2015 | Frigidaire Dryers
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
My dryer does everything it is supposed to do except fully dry the clothes. I took the back off and cleaned everything. I even pulled the heating element out and made sure all the coils were heating up. It...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Sep 03, 2010 | Estate TEDS840JQ Electric Dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dryer is not drying clothes. We need to put clothes through 4 or 5 cycles to dry. I have checked the vents and everything is clear.
heatman101
Aug 09, 2010 | Maytag Dryers
Frigidaire Front Load Dryer Model # leq2152eeo Problem: it is not drying the clothes. The dryer heats up and everything else is working, except it takes 4 cycles to dry something that should have dried...
while the dryer is running.go to the outside of the house and check the air flow,there should be a large amount air being blown out if there is not check the vent and ducting for lint build up and make sure the hose is not kinked.
when there is restricted air flow all the warm moist air will stay in side the dryer causing the clothes to take a long time to dry. i hope this helps you with your dryer
Jan 24, 2010 | Dryers
Takes too long!
This may be caused by a partially burnt out heating element, a faulty thermal fuse, or a faulty high limit thermostat. I would start with the thermal fuse. It is located just inside the back of the dryer and is usually mounted on the exhaust duct. The components can be checked with an ohm meter or multimeter for continuity. If the component shows zero ohms, it is defective and must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Roper REX4634KQ Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Heat without Drying - Whirlpool Dryer
The exterior exhaust vent for the dryer was locked shut not allowing the air to escape. So hopefully that will completely solve the problem!
Mar 30, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
251 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
