Question about Maytag Performa PAV2200
Series of clicks..then dead
My wife put too many towels into the washer and didn't realize the setting was on the smallest load. At the beginning of the rinse cycle, there were a clicks and then nothing. Thanks in advance for your help.
  • 183 Answers
The load size adjustment only changes the level of water used, this could not cause a fault,sounds like a faulty rinse valve or depending on model a faulty or blocked pump. Regards Engineer
Posted on Jul 30, 2007
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
Soap coming out of washer
wrong soap check your use care guide for proper soap. check door gasket for anything on it. the smallest peice of debri can make it leak. over loading can make it leak
Dec 25, 2009 | LG WM2487H Front Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
My new washer did not spin out the water
if its a new washer call and have them trade it out for another one.
Dec 31, 2008 | Samsung WF337AA Front Load Washer
Wash tub seems loose and is really loud
We just had that same problem last week. My husband took off the back of the washer and at the bottom you will see a shock absorber on each side. One side of ours was broken. $35.00 later for the parts (you get two in a package) and the tub is sturdy once again. Husband said it was fairly easy to do. Hope this helps!
Dec 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
