Question about Kenmore 24032\24036 Top Load Washer
Dropped a rag between Outer wall and inner wall
I've dropped a rag between Outer wall and inner wall of the washing machine (top loader kenmore) while I was cleaning the build up in the water recycle rim under the opening of the washing machine, where the wash water filters back in the machine again. While I was cleaning this build up gunk, my wash rag slipped the other side, in the tank I cannot get to. How can I get this rag out of the washing machine without calling a repairman?
    Scholar:
  • 63 Answers
If the machine still works fine with no new noises like the rag getting caught in a belt or something, I would forget about it and continue use as normal. Obviously, one should not run machines like this without being close enough to hear it if it has a major malfunction, so you should be fine, especially after the first new test use of it.
Since there is no flame or great heat in a washer, a loose rag inside should not be the problem that it could in a dryer! Best wishes!
Posted on Dec 09, 2008
  • John Ballou
    John Ballou Dec 12, 2008
    An invaluable tool around any house is a retriever tool the looks like a spring with a plunger on one end and pick-up hooks on the other, enabling one to pick up small objects or even cloths that on down in deep crevices. I use mine often to get an object out of my auto engine that has dropped into some narrow space. They are available at Walmart or any swap meet. This will prove worth it weight in gold to you for this any many future similar problems!
Hello I have kenmore washer m 110.28072800 wash cycle doesn't finish, doesn't agitate clothes, get oL on display. Anyone had this problem?
If you haven't got it now, google your model of top-loading washer - manuals are always helpful - Being it is a top loader, oL as most can expect means overload! The simple response is to unload some of the clothes and try doing a smaller load - the newer top loader machines are not as 'strong' as the old days with an agitator - second possibility is whether or not you have lost something that has gone down between the inner and outer bowls that make up the washing are - not sure as I have not seen one exactly, but most of the bowls where the clothes sit, have holes - anything stuck in a hole causing the inner and outer bowls from working as they were designed? good Luck
Nov 02, 2017 | Kenmore Washing Machines
How to block the tub for moving across country?
front loader or top loader
need to get between the drum and washing machine inner casing
polly styreyn.. rags .lots of bubble wrap thick cardboard
Apr 01, 2017 | Washing Machines
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to drain the inner tub of washing machine
we dont have much call for top loaders in the uk, but if they are like front loaders, there should be a filter at the bottom either on the left or right. if so, pull the machine forward and then tilt it back against the wall. not too far in case it slips forward and lands on its back.
remove the filter cover and then using a bowl and plenty of towels, tilt it forward and let the water run out.
hope this helps
May 12, 2014 | Washing Machines
How do I remove the top of whirlpool awoe 9140 front loader washing machine?
there are 2 or 3 screws behind the top cover,but this wont get you to where the odor exists,its in between the inner and outer drum,you need to also remove the front cover including the door then remove the inner drum pulley and belt and then split the outer tub to clean out old detergent and fabric softener if you use this as this is where the smell is coming from
Jan 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
How to remove outer washplate from. kenmore
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Kenmore Washing Machines
Big black dingemalieries after wasching with the machine
sounds like something foreign got dropped into the tub with the laundry.try washing some rags.if still there,remove agitator and inner tub.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Kenmore 24032\24036 Top Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
