Question about Dryers
Kenmore model 41783142300 no heat
Power is good to unit, good heat element, any other suggestions as to problem
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 1028 Answers
SOURCE: how to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Posted on Jul 05, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer does not heat.
DEAD DRYER
Posted on Feb 07, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore dryer model 96281100 runs but don't dry(no heat)
If the Thermal Fuse were blown, the dryer would not run at all. If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back with your complete model number (located on a nameplate around the door opening) so I can provide you with better service. I hope you find this information is helpful.
Posted on Feb 27, 2010
SOURCE: Hot water heater Model EE3J40RD045V
how to change lower heating element on water heater Whirlpool ee3j40rd045v
Posted on Apr 24, 2010
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Replacing heating element in Kenmore model 110.65922
The heating element will have multiple coils to it with two leads coming into it. POS/NEG. If that is it then it is very strange that it is not enclosed in some way shape or form.
Feb 12, 2014 | Kenmore Dryers
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore Dryers
Kenmore model 58072187300 a/c and heat window unit. When I Set on heat , i barely feel the air get warm.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heating element check power toelement. If power is there but still no heat means element defective. Replacenew heating element. Thanks
Jan 10, 2011 | Maytag M7Y15F2A Air Conditioner
My heating element isn't working on my kenmore dishwasher. Any suggestions? model # 13429
The # you gave is the catalog number. Please provide the model number, which is in the format abc.defghi . . . .
How do you know the heating element is not working? Could there be another problem causing the element not to operate?
Dec 18, 2009 | Kenmore Dishwashers
Kenmore Dryer -will spin but not heat and dry
The ohms reading on a heating element should never be zero. The resistance is what turns electricity into heat. You may have gotten a bad part. Check it again with NO power to the system. Unplug it or flip the breaker to be sure. You should definately get a reading on a good element. Good luck
Dec 06, 2009 | Dryers
I have a Kenmore special edition model # 110.63912100 (S/N ML350387S) that will not heat. What do you suggest, heating element, thermostat, or ???
first make sure you have 240 going to the dryer.you will nead a meter check this.if you have 240 ,than you nead to unplug unit.pull unit out and take back panal off.on the right side you will see the heating colom.at the top is one of the high limit switch's.you will nead a continueaty meter to check this.at the bottom you will see the other high limit switch.make sure you unplug wire's before you check them.under thst you will see the heating element.remove wire's and check out element.also look for bad wiring.if all check good, you nead to call for service call.
Nov 16, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer model 41783142300
this is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
  • picture is from fixitnow.com
Jul 21, 2008 | Kenmore Dryers
Dryers Logo
137 people viewed this question
Top Dryers Experts
