Question about IBM NetVista A40 PC Desktop
When I start my computer I get an error message: Disk I/O error.
After starting the computer I receive the follow message:
Disk I/O error
Replace the disk, and then press any key
    Sniper:
  • 60 Answers
I agree with wigglybus. Check that there isn't a usb device plugged in or a floppy in the drive if you still use floppies.
Posted on Dec 09, 2008
    Scholar:
  • 86 Answers
Some bios will not boot if you have a memory stick in a usb socket. Just make sure you havn't! other wise I agree with previous thread - most likely some failure causing the hard drive not to be recognised
  • 837 Answers
The hard drive in that PC is failing or has failed. The drive controller is failing or failed. The drive controller on the motherboard is failing or failed.
Too many possiblilities but you should get the drive looked at first.
And I would suggest not truning that PC on anymore until you do so
Keep getting black screen with error message no bootable device - insert boot disk and press any key ... computer will start in safe mode if i'm quick enough with the f1 key ... HELP
Hello good day, just remove your SATA cable from your hard disk if your using a SATA type HARD DISK, change with a new one, or try to pull it back and put it back tightly. It's just a loss contact situation.That's why you are receiving that message.
Mar 14, 2012 | eMachines T Computers & Internet
My computer crashes a lot. How do I fix?
You may run or perform Disk Error Checking(This is for Windows XP SP3):
* Chkdsk (Chkdsk.exe) is a command-line tool that checks volumes for problems. The tool then tries to repair any that it finds. For example, Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors.
** How to run CHKDSK at the command prompt:
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
  • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
  • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
    Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
  • Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
  • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
  • Once done with chkdsk r, run FIXBOOT and press ENTER.
    Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
  • Sep 08, 2011 | Dell Dimension 4600 PC Desktop
    My vista is not performoing well .it dosent startup properly.only a black screen is comming.no msg is coming.it is only working in safemode.now i am in ubuntu
    Resolution : Fallow method 1 or method 2 no data will be deleted.To resolve this issue, you must have the Windows XP CD-ROM. If you do not have the Windows XP CD-ROM available,
    If you have the Windows XP CD-ROM, use one of the following methods. Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
    1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
      For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 A description of the Safe Mode Boot options in Windows XPIf you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
      Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
      1. Click Start, right-click My Computer, and then click Manage.
      2. Expand Storage, and then click Disk Management.
      If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
      If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
    2. Run a current virus scanning program to verify that no virus is present.( In safe mode)
    3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
      For more information about how to use the Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base: 307654 How to install and use the Recovery console in Windows XPNote For more information about an error message that you may receive when you use the FIXMBR command, click the following article number to view the article in the Microsoft Knowledge Base: 266745 Error message when you run fixmbr commandWarning If your computer is infected with a virus and you use the FIXMBR command, you may be unable to start the computer. Before you use this command, make sure that the computer is not infected with a virus.
    4. If the primary boot partition is a FAT partition, use the FIXBOOT command from the Windows XP Recovery Console to write a new boot sector on the system partition, and then use the FIXMBR command to repair the master boot record.
    Method 2: Repair your Windows installationNote Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
    1. Use the Windows XP CD-ROM to start your computer. On the Welcome to Setup screen, press ENTER to set up Windows XP.
    2. Press F8 to agree to the license agreement.
    3. Use the ARROW keys to select the Windows XP installation that you want to repair, and then press R.
      Windows XP Setup repairs the installation files, Windows XP automatically restarts, and then the Setup program finishes the repair of your Windows XP installation.
    4. Follow the remaining steps to set up Windows.
      Note You must have your 25-character product key to complete these steps.
    5. As soon as this issue is resolved, make sure that the firewall is enabled, and then visit the following Microsoft Web site to reinstall the latest updates: http://windowsupdate.microsoft.com/
    6. Run a virus scan on the computer because problems with corrupted elements can be attributed to viruses.
    Dec 26, 2010 | Computers & Internet
    Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
    The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
    Press F1 to ignore the error, and to boot from your C: drive.
    Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
    Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
    Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    Hi wht to do as error 0x000000ED
    When you first restart your computer during the upgrade to Windows XP, or when you start Windows XP, you may receive the following error message:
    STOP 0x000000ED (0xaaaaaaaa,0xbbbbbbbb,0xcccccccc,0xdddddddd)
    UNMOUNTABLE_BOOT_VOLUME
    Note In this error message, aaaaaaaa, bbbbbbbb, cccccccc, and dddddddd are hexadecimal numbers that may vary.
    If you receive this error message when you restart the computer for the first time during an upgrade to Windows XP, your original operating system will still work correctly. In some cases, you may see a message that states that the wrong cable is being used. However, you may not see this message on computers that have a fast startup time.
    Advanced troubleshootingThese methods are intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, use the Microsoft Customer Support Services Web site to find other solutions, or contact Support. See the "Next steps" section for more information about the Microsoft Customer Support Services Web site.
    Begin by reading the "Technical information about the error" section to understand why the error might be generated and the purpose of the message. Otherwise, you can skip this information and begin with "Method 1: Check the error message" to help you resolve the issue. Technical information about the errorThis section provides some technical background about the cause of this error message and why it might be generated.
    This behavior can occur if either of the following conditions is true:
    • Your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and the following conditions are true:
      • You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
      • The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
    • The file system is damaged and cannot be mounted.
    The purpose of this error message is to prevent the following two things:
    • Potential data loss caused by using an incorrect IDE cable for the faster UDMA modes. An IDE cable is a kind of cable used to connect storage devices, such as hard disks, inside a computer.
    • Continued access to a drive on which the file system is damaged
    Feb 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
    My ATI Catalyst Control center Problem was first.
    Your hard drive sounds like it's about to fail. MAKE BACKUPS NOW! I would start in safe mode and backup all my important files to an external source. Then I would run a chkdsk, here's how:
    Double-click My Computer, and then right-click the hard disk that you want to check.
    1. Click Properties, and then click Tools.
    2. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
    3. Use the following procedures:
      • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
      Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
    Please don't forget to rate this solution.
    Jun 13, 2009 | Computers & Internet
    Computer just shuts down
    Run an Error check on your computer. Process takes anywhere from 1 to several hours, depending on hard drive size, files on computer and number of errors needing to be fixed. Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
    1. Click Start, and then Run.
    Jun 04, 2009 | Acer Aspire RC500 PC Desktop
    Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
    1. Start the computer and make sure that the current version of Windows has started.
    2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
    3. If the Setup program does not start automatically, follow these steps:
      1. Click Start and then click Run.
      2. Type Drive:\setup.exe and then click OK.
        Note Drive is the drive letter of the computer’s DVD drive.
    4. When the Setup program starts and the Install now screen appears, click Install now.
      Note When you receive with the Get important updates for installation message, click Go Online.
    5. Click Upgrade when the Which type of installation do you want? screen appears.
      If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
    6. Follow the instructions to install Windows Vista.
    If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
    If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
    Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
    5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
    If Windows Vista is now running on your computer, you have completed the installation successfully.
    If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
    To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
    1. Start the computer.
    3. Restart the computer.
    4. When you receive the "Press any key to boot from CD" message, press a key.
    5. Follow the instructions to install Windows Vista.
    Nov 27, 2008 | Computers & Internet
    How do I re-format a 2x serial SATA drive to reinstall XP?
    How to Format a Hard Disk
    After you create the partitions, you must format the partitions:
    Restart your computer with the Startup disk in the floppy disk drive.
    NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
    2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
    NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
    Extract ebd.cab format.com
    After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
    3. When you successfully run the Format.com tool, you receive the following message:
    WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
    Proceed with Format?
    4. Press Y, and then press ENTER to format drive C.
    5. After the format procedure is finished, you receive the following message:
    Volume label (11 characters, ENTER for none)?
    NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
    Jul 25, 2008 | Computers & Internet
    IBM NetVista A40 PC Desktop Logo
    645 people viewed this question
    Top IBM Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
