Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
I need a Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM electric ignition GAS FURNACE.
Igniter turns red hot but the Gas Valve just shakes and makes a clicking sound and then the ignitor will go out.
Furnace does not fire up and fan does not kick in.
Gas valve is Honeywell Part# VR8205A 2008 reg 3.5 ADJ 3-5 Range 24V 60HZ total current .5 A uses class 2 transformer.
I also do not see any type of control board with a digital read out flashing any error code. Please Help.
  • nwilliams119 Jan 06, 2009
    I have the same furnace and the same thermostat and pretty much the same problem. Please advise.
Replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Posted on Dec 29, 2009
I have a RHEEM RGUJ-05EA-ER GAS FURNACE in my attic. early in the morning and late at night when the temperature is low it does not trigger on. The thermostat is new as well as the HOT SURFACE IGNITION...
Couple ideas here. First is make sure the thermostat is level. Most do not work unless they are level. Second, make sure there is enough fresh air. It make have a low oxygen sensor which keeps it from lighting.
Dec 28, 2014 | Heating & Cooling
Rheem Furnace
do you have a standing pilot or electronic ignition furnace........you could have a problem with a safety switch, bad electrical connections, electrical short, circuit board issue, hot surface igniter issue....etc...........need to know the type of furnace
Dec 05, 2013 | Heating & Cooling
Rheem pool heater
Gas on, door safety switch, fuse box breaker on? New install, older, or shut down while in service. Please give more details. Make trouble shooting easier and get you fixed up fast. Thank you.
Oct 06, 2013 | Pool & Spa
My rheem electric igniting furnace is lighting and going out over and over. It is model number M3UF032SA. Thank you!
Replace thermo-coupler . Should be able to take urs out and take it to a hardware store and match it .
Make sure u shut gas off before removing
It .
Dec 20, 2012 | Heating & Cooling
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
Furnance will not heat
Check your voltage going into the gas valve. It should be 24-27 volts. If it is to low the gas valve will chatter. If the voltage is strong enough you have a bad gas valve.
Dec 09, 2008 | Heating & Cooling
Furnace will not light
What code is the control board flashing when it tries two or three times? Does it even fire? Does it go straight to fan and lockout?
Heating & Cooling Logo
1,396 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
