Question about Brother Office Equipment & Supplies
Cannot fax, copy, etc.
- For approx. 2 wks. readout was yellow cartridge needs replacing. Had never used anything but black so ignored and continued to use with no problem. Replaced the black about a week ago and have been able to fax and copy. Now, just recently message readout says "No cartridge - yellow" and instructions on opening cartridge door and replacement.
Cannot fax or copy now.
    Problem Solver:
  • 18 Answers
Could you tell me the model number please as I had this problem today and I think I might have an answer for you.
Posted on Dec 09, 2008
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Fax says to replace yellow cartridge...
There is a menu prompt that allows you to choose to print in black only.
Sep 16, 2008 | Office Equipment & Supplies
Low Ink
I get that when I have just refilled the cartridge, but I usually ignore it and it is still ok for a while; have you checked that you are using draft or normal not best settings?
Jul 29, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
