Is this in the right section, Cars and Trucks? Or are you talking about a cell phone screen protector. You can use some rubbing alcohol to remove tab glue. You can also try the non-sticky side of scotch tape or wd-40 as discussed in the thread here:
Soak a cotton ball with WD-40 (or equivalent) and apply it to the sticky residue area. Allow it to penetrate for a couple of minutes. Then gently wipe the area with that same cotton ball until it loosens and picks up the adhesive residue. Once that's done, simply cleanse the treated area with any dishwashing liquid or similar. Rinse and wipe dry.
1) Make sure device screen is ABSOLUTELY clean.
2) Make sure your hands, and workspace are also clean and lint free, then DOUBLE CHECK #1 above.
3) The pro's use a "wetting" solution to settle the protector onto the screen but NOTE !wetness is generally bad for electronics !, so " a little, is good. More is NOT better!"
4) A small plastic squeegee is usually included with any "quality" protector kit. USE IT GENTLY! move the squeegee from the center toward the edges, pushing excess solution or bubbles as you go. Excess pressure stretches the protector and causes bubbles to form as the protector settles.
5) Once the protector is bubble free, in the correct place, and not hanging over the edges. LEAVE IT ALONE 'TILL IT DRIES AND SETS.
NOTES If your protector is one that uses an adhesive coating to hold it in place, DON'T TOUCH THE ADHESIVE SIDE WITH FINGERS (or anything else for that matter) because that's what makes dimples that trap bubbles. This process is proof of the saying "You only get one chance to do it right the first time!". If after the process is complete, and if you find there are still bubbles, you may try again but the likely chance of removing and replacing the same film without damaging it is very small. Fortunately, protector screens usually aren't too expensive (compared to the price of a damaged phone/tablet). Good luck!
Ease of Application and Removal. You shouldn't have to be an accomplished brain surgeon to apply a screen protector properly. The best protectors go on easily without leaving air bubbles or requiring constant repositioning. If you do need to adjust your protector, it should move easily so you don't have to throw it away if you don't get it right the first time. If you want to remove the protector altogether, it also shouldn't leave sticky adhesive residue on your screen.
Hello Sir,
It seems that you have got dust in the inner adhesive part of the screen protector. If that is so, there isn't a way to clean it. You have to get a new screen protector. If you have dust and other particles on the screen protector, then use a micro fiber cloth. That is the best.
A heat gun (careful, some heat guns will remove paint!), or 1200 or higher wattage hair drier held over the tape while sliding a putty knife under the paint is the best method. The heat softens the adhesive and makes the tape easier to remove without damaging the paint. You'll still likely have to go back with lighter fluid and a cotton cloth to remove the adhesive still stuck to the paint. Don't use acetone or paint thinners, they attack the paint!
well go to wal-mart get some goo gone very carefully with a razor get under the adhesive apply goo gone as it lets go work slowly with razor being careful of the paint continue until removed the use goo gone to remove remaining adhesive use a little polishing compound then apply wax
