Question about Daewoo DTS42 42 in. HD-Ready Plasma Television
Fix it myself what to do
Dozen or so lines when turn on need to know what to do to fix myself
    Champion:
  • 217 Answers
Check the LVDS cable and all the other cables inside to make sure that they are plugged in all the way, otherwise it could be a bad panel
Posted on Apr 16, 2007
It looks like the intake manifold gasket is leaking and i cant find repaire info anywhere. i just wanted to know what i will need to do the job myself and if you had some kind of a diagrm for it?
Go to www.autozone.com and register for free. Once registered you'll have free access to dozen of DIY repair manuals. You will need a good socket set and a torque wrench plus some other standard tools.
Jan 27, 2011 | Ford Explorer Cars & Trucks
Picture image is unsettled when you 1st turn on the TV - Eventually gets better after warming up for 15 minutes. Rear projection HD 56" screen - About 8 years old.
LINES or noise from left to right etc. This is a classic problem in a lot of these sets--that this clears up after a while is also typical---the period will gradually get longer and longer for it to become normal.
This set uses a Hyper board for all signal from all inputs---about two dozen tiny surface mounted filter capacitors on that board---they dry out and lose value---flat caps will when hot attempt to regain some of the value they should have.
Board is no longer available from Toshiba, only way to fix is remove one in set and send out for repair to someone like PTS Electronics.
I have seen experts try to replace the tiny caps--usually several are off value or open---cheaper to send board out. Last one I saw cost was about 200 for rebuild, keep in mind same problem will happen again in 5-8 years.
Let me know if you have questions and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Our Saeco italia has an error message: Need to prime. but it will not prime when water knob is turned on...
i had this same problem and it turns out a small mineral deposit was lodged in the water line, right before it went in to the second heater (to make steam). The cost to repair and shipping was pretty high, so i fixed it myself and it's not too hard. You can try de-scaling. If you want take the water line apart, let me know and I'll walk you through it.
Aug 16, 2009 | Starbucks Saeco Italia Digital Barista...
89 Chevy Beretta Fuel Lines
how do you know it needs fuel lines, are they leaking? is fuel pump good?did you do fuel pressure test? did you chk. to see if filter is pluged? just because the tank leaks won't keep it from running and that can be fix with a little apoxey and a some elbo grease.
Feb 02, 2009 | 1989 Chevrolet Beretta
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Dec 09, 2008 | JVC AV-36950 TV
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Oct 14, 2006 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Daewoo DTS42 42 in. HD-Ready Plasma Television Logo
64 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
