Question about Acer Aspire 3000 Notebook
Memory Upgrade for Philips Freevents x57 laptop
In attempts to upgrade the RAM from 1gb to 4gb under vista, the graphics card no longer finds free resources and runs in 4bit. Is there anyway to get the graphics card to recognised the newly installed memory?
Thanks in advance!
  • David Cates May 11, 2010
    Right Click on the Computer option in the Start menu it will bring up a list of options click on properties. Is the computer reading all 4 gigs?
Can I install a secondary graphics card in Acer Z5801 all in one pc
Yes you can upgrade the Graphics Card on the Acer Z5801. There is an optional Graphics Card slot on the Motherboard and you will need an Acer Geforce GT 530 Graphics Card. They come in 1GB and 2GB but quite rare to find. Your best shot is an Acer Distributor. For more help have a look at the link below:
http://www.opendzine.com/content/acer-z5801-all-one-pc-ram-memory-hdd-graphics-card-upgrade-and-maintenance
Jun 21, 2012 | Computers & Internet
I have ACERT EMACHINE 250 NETBOOK THAT BROWSE VERY SLOW AND I AM USING WINDOW 7..PLS WHAT COULD BE THE POSSIBLE PROBLEM AND HOW CAN I RESOLVE IT. THANKS
In that case you should upgrade your Ram,memory and graphics card.If you are using 1gb Ram then upgrade it to 3gb by adding 2gb Ram.Then you can see the difference.You can also upgrade your memory like that.If you are using 500gb Memory then upgrade it to 1tb Memory.Then you can see and feel much difference.Upgrading graphics card is an optional thing.If you upgrade it you can see difference in gaming and in your system graphics.
If you do all this things surely your system will improve it's performance.
Apr 07, 2011 | Computers & Internet
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
How do I find my graphics card on acer laptop 4720z and change settings to best play games
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Acer Aspire 4720 Notebook
Does Nvidia Quadro FX3400 support 4gb of RAM? My
If there would be no increase in performance, no need to do upgrade. try to check the performance of your computer using BENCHMARK softwares.
Oct 18, 2009 | HP Compaq NVIDIA Quadro FX3400, (256 MB)...
How to find the best graphic card for hp pavilion dv6 2.66GHz., 400GB memory and 4GB ram notebook.
Laptop or Desktop? If its a laptop its next to impossible to upgrade the video card. If its a desktop, can you please provide the exact model number.
Jul 10, 2009 | Nvidia Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
207 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
