Question about Honeywell HWM-450 4 Gallon Humidifier
Vapor mists, but humidity stays the same (dry)
I have a honeywell 4 gal quicksteam. When I plug it in it reads 20% humidity. I set it for 50% humidity at full force, but 4 hours and 3 gallons later, it is still only 20% humidity. Is it broken. The room I am trying to humidify is 14 x 18. I closed the door and turned off the heater, but nothing.
  • 2 more comments
  • Anonymous Dec 22, 2008
    I had the same problem. Even put the humidifier in a small bathroom and measured the humidity at over 50% but the reading on the humidifier was still 20%, consequently it never shuts off. I have now replaced it and hope the new one works OK
  • Anonymous Dec 30, 2008
    Humidity always reads at 20%
  • consumer44 Jan 11, 2009
    Just bought the HWM-450 and I have the same issue with the humidity staying stuck on 20%. It worked ok right out of the box but on the second filling it read 20% and hasn't moved for 4 days. I'm researching now and find that other have this same problem. Sounds like a design flaw. Other than that it seems like a good unit. I like that it doesn't need expensive filters and it's easy to maintain but if the humidity meter doesn't start working I'll probably return it.
  • Anonymous Jan 13, 2009
    Same problem here.
SOURCE: honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: Honeywell Humidifier
The demineralzation cartaridge seems to be the issue. Remove it and see it the misting starts. If it does put a hole in the center cylinderical support of the demineralzation cartaridge, the one that fits over the white positioning post that is built into the base of the humidifier. This will allow the cartirdge to sink to the bottom and not interfer with the water tank plunger opening up and filling the base.I opened the hole completly but I think a smaller hole will do.
Posted on Mar 16, 2008
  • 104 Answers
SOURCE: Am looking for the owner's manual for the
you can download here
http://rapidshare.com/files/225370310/4858c9fccc48b69c50a7b921cff38680.pdf.html
Posted on Apr 24, 2009
heatman101
  • 43501 Answers
SOURCE: My Honeywell Humidifier worked last
For the humidifier to work you need to have th blower running do that means that you either have to turn the blower on manaually or the heat must be running alot...
I would suggest that you turn the blower or fan switch to the on position for a few days to force the blower to run...this will get the humidity up and then you may have enough runtime for heating for it to keep up then...
heatman101
Posted on Nov 12, 2010
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Posted on Dec 16, 2010
I need the operation manual for the Honeywell quick steam humidifier HWM335, 3 gal. please
Here is a link to your Owners Manual that you can download and print. Please do not lose it, as this model has been discontinued by Honeywell.
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/QuickSteam-OwnersManual.pdf
Mar 23, 2011 | Honeywell QuickSteam HWM335 3 Gallon...
I cleaned my Honeywell Quicksteam 3 gal. Now it won't turn on. Yes I have pressed the reset button
after your resetting try to start by pressing on button or try to reprogram the setting on digital thermostat ok.
Feb 04, 2011 | Honeywell QuickSteam HWM335 3 Gallon...
Hi I need help understanding the controls to my humidistat. I have a honeywell a/c unit so I'm assuming the gold colored humistat next to it is also honeywell. I bought a digital temperature and humitiy...
The higher the % of RH, (relative humidity), the more humid the house will be. I would disregard the temp part of the dial, and focus more on your comfort. Adjust it up daily until you reach a satisfactory humidity level. Hope this helps
Dec 19, 2009 | Honeywell Power Humidifier: Furnace...
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
Short cycling
It doesn't sound like it has failed.
The whole point of the % setting is so that the room holds at that %. When the humidity drops lower than, it will kick in. When it raises to that number it will turn off.
If the on and off is bugging you try raising the percentage. Or lower the temperature of your house. Heating will dry out the air and cause your machine to kick in.
Good Luck.
Feb 18, 2008 | Hamilton Beach Cool Mist 05521 Humidifier
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Honeywell warm mist humidifier shuts off
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Honeywell HWM-450 4 Gallon Humidifier Logo
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
