Question about RCA D56W20 56" Rear Projection Television
Power Problem I've got an RCA D56W20 that will turn on and work great for about 10 minuts then the picture will drop out. After doing this for several cycles all of varying times, the tv will shut off. I am thinking one of the components are overheating, because after a few minuts, you can turn it back on and it'll do the same thing again. A repair man came out and wanted to replace the board that the flyback transformer is mounted on, but he wanted $350 for the board plus labor. I Repaired TV's for about 1 1/2 years after highschool, but I am definatly not an expert (plus its been over 8 years ago). Any halp would be GREATLY apreciated.
    President:
  • 1,284 Answers
There are two different chassis used in that model. If yours has chassis # ITC222 then the part number will be 264102 if it is chassis # ATC221 then it will be part # 258762. The defelection board for the ATC221 is the cheapest. Here are two links for both to order. http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187237&ProductType=PART http://www.partstore.com/ProductDetail.aspx?ProductSKU=7747288&ProductType=PART
Posted on Mar 13, 2007
I have an RCA model D56W20. When I press power, the light flashes 3 long flashes then nothing. No picture, no sound.
I may of seen a different version of this question a few days ago, The set has a 3 strikes and you are out (not a joke) as it will try 3 times when powered up to come on and then go into shutdown.
Most common issue is bad solder connections under the High voltage transformer (see photo of typical one).
Not knowing your skill level let me know how you want to proceed.
Dec 05, 2012 | RCA D56W20 56" Rear Projection Television
Bad convergence rca d56w20
if model number is correct this is not a do it yourself repair.
Confirm actual model number and I will help you.
Nov 19, 2011 | RCA D56W20 56" Rear Projection Television
RCA D56W20, Works OK, so long as the "black level"
The green CRT has an issue and will need to be replaced. It could be the Green CRT drive board but doubtful as your describing the classic sign of a CRT thats developing a Short . You can get replacement green CRTs and CRT drive boards from www.tvrepairworld.com
Oct 14, 2011 | RCA D56W20 56" Rear Projection Television
I have a 56 inch RCA D56W20 and when i turn it on I can hear the sound, but i can't see any picture.
In menu check the Lamp Hours You may need a new lamp or the lamp has failed
Please rate my help++++Thanks for using FIXYA
Aug 13, 2010 | RCA D56W20 56" Rear Projection Television
RCA d56w20 changes aspect size and picture appears jumpy
Thats caused by the small signal board, which is actually a board known to fail when the aspect changes on its own like that. You can get replacement small signal boards at www.tvrepairworld.com
Mar 30, 2010 | RCA D56W20 56" Rear Projection Television
Tv turns off and takes a few minutes before you can turn it on.
Filters are bad in power supply. If you need further assistance call a technician.
I'm local to 80634 zip and would be happy to help.
Wilbur Stringer
Westview TV
Jun 30, 2009 | RCA D56W20 56" Rear Projection Television
RCA D56W20 picture problems
More information is required to properly troubleshoot this problem. How is your television connected when you are watching HD? Do you have HDMI for this, do you have a satellite or digital cable box? For analogue are you using regular coax antenna (cable TV), or are you going through a cable or satellite box?
This could be related to the aspect ration setting. perhaps you ahve changed your aspect ratio from 16:9 to 4:3 or some other setting. If you are connected via HDMI, then the digital signal may be "normalizing" your picture during HD, but reverting back to the other setting.
Check you video settings very carefully. HD televisions are very difficult to tweak properly.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D56W20 no power and whistling
ok. the FLyback is the large black part on the lower left corner.. has large red wire comeing from it... the HOrizontal.. is the large black transistor right in front on the left side on the largest heat sink..getting these parts are tricky.. you must get some numbers on the part itself..there are three different flybacks.... and the horizontal is ussally 259899 rca part number. Good luck and if you need any more assitance email me at FORDTV.com ; I work on alot these chasis
Nov 04, 2007 | RCA D56W20 56" Rear Projection Television
RCA D56W20 56" Rear Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
