Question about Randell RAN-94017 Refrigerated CounterSalad Top 27""L 30""D 1 sect
I cannot figure out how to configure our support bars for this refrigerator.  It seems as if the inside support lips are not designed to hold the support bars.  I am using numerous 12" lock-in bar adaptors as well as 16" lock-in bar adaptors with three slots in them. Help!! Thanks
I called the technical support line for Randell, and they helped me figure out the support bar layout.
Posted on Dec 10, 2008
WHAT THE CUBIC FOOT SIZE FOR THE MEASUREMENTS OF 62"H x 23.5"W x 24"D?
The cubic ft capacity spec on a fridge is measured inside, and varies depending on its design, especially on whether it has an ice maker, although those measurements you give seem to be for a bar fridge or similar.
Your measurements come to 20.3 cu ft on the outside, but remember that is not relevant, you have to measure the dimensions to make sure it fits.
Feb 25, 2016 | Refrigerators
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Replace freezer gasket
Lift the lip of the gasket from the side, and unscrew the screws holding the gasket holding bar. Rest is easily figured out how.
Mar 16, 2014 | Sub-Zero 650/SRH Stainless Steel
Chain loose
Chainsaw bars get loose all the time. This can create a dangerous situation.
Tightening the chain is done through the positioning of the bar. The further away from the drive gear it extends, the tighter the chain is.
The are usually two nuts holding the bar on. These need to be loosened slightly to allow the bar movement.
Depending on your model there may be a guard over them. Remove it.
Once the nuts are loose, locate the tensioning screw. It will be relatively small, located adjacent to and facing parallel to the bar.
This screw is attached to a metal lip that in turn is attached to the bar. The screw remains in one place while the lip moves up down.
Start spinning. Keep going until the chain is tight.
Tighten the Bar Nuts, replace the guard if necessary.
Now go slice some wood.
Best regards
Mike
May 17, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
1998 LeSabre center storage console doesn't open
Place the palm of your hand on the top and curl your fingers under the lip and press upward toward your palm,it should then open.When open you can fold the cup holder inside the console.
Dec 20, 2009 | 1998 Buick LeSabre
Kenmore trio Refrigerator (bought 9/1/07)quit running message bar inside refrigerator read error. I shut off power waited a minute or so turned power back on seems to be running. What could have caused the...
sounds like its a sticky thermostat and the fridge started to warn up to much,,, the compressor was not told to start up so up come the error message,, it could work out ok now but dont hold you breth,,,
Oct 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cleaning refrigerator & have a bar I don't know where it goes Whirlpool Model - ET1CHMXKQ02
If the bar is long , it probably fits inside the crisper cover which has a U shaped slot for the bar to slide into .
Aug 25, 2009 | Whirlpool Refrigerators
Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
Randell RAN-94017 Refrigerated CounterSalad Top 27""L 30""D 1 sect Logo
70 people viewed this question
Top Randell Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
