Question about Panasonic KX-T7633 Corded Phone
KX-T7633 DOESNT TURN BACK ON AFTER UNPLUG THEN PLUG BACK IN.
I DISCONECT THE PHONE WHEN I PLUGGED IT BACK AGAIN IT DIDNT TURN ON, UNPLUGGED ANOTHER ONE TO TEST THE FIRST ONE I UNPLUGGED NOW BOTH OF THEM WONT TURN BACK ON.
SOURCE: how to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Posted on Oct 02, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
Posted on May 07, 2009
cnavarro
  • 2460 Answers
SOURCE: Change date for KX-t7633
Enter System Programming and choose option 000 the time and date are both settable from there.
Carl
Posted on Jul 11, 2009
ybchuan
  • 201 Answers
SOURCE: Headset set up on a KX-T7633
First make sure that your headset is really compatible with the Panasonic phone. After plug in the headset to phone then u need to enable the headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
4) Press EXIT or PROG.
YBC (/\)
Posted on Oct 19, 2009
  • 547 Answers
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Posted on Dec 02, 2009
How to setup Remote Extension on KX-T7633?
Hello Luis what model of phone system are you using?. Is it an IP-PBX system? What exatly do you mean by "I also have a couple phones running directly off other phones" and ."when an outside call comes in that phone that is running off the other one doesnt ring".We could be of help
Apr 10, 2014 | Panasonic KX-T7633 Corded Phone
Phone Display
Panasonic KX T7633 user manual pdf
the link above is the manual
The Panasonic KX-T7633 is a telephone that will satisfy your demand for a user friendly operation. You can enjoy the hands free conversations offered by the speakerphone facility that the Panasonic KX-T7633 features. The 2.5 mm headset jack that you will find in this Panasonic KX-T7633 phone will enable you a hands free usage for paperwork or PC. It has a 3 line LCd that gives you a readable and clear display. It is available in charcoal and white color. This phone gives you an opportunity to choose the right color that will go along with the d?cor in your home or office. This device looks professionally because of the executive design. The Panasonic KX-T7633 has 24 programmable keys with dual color LED. It also has a 3 line caller ID LCD with back light. You will love the headset jack. It supports caller ID. The Panasonic KX-T7633 has a speakerphone, Intercom, automatic redial and an LCD display. There is a chance for 8 way conference call. It also features a digital XDP (eXtra Device Port) jack. I warmly recommend this phone for your home or office. You will be extremely satisfied. Panasonic phone models are very durable and you can use it for years to come. It will serve well to your every wish. Before using the Panasonic KX-T7633, it is recommended to read the Panasonic KX-T7633 user manual. If you have lost yourmanual, you can always download one here, free of charge: DOWNLOAD PANASONIC KX-T7633 USER MANUAL PDF
Jan 07, 2014 | Panasonic KX-T7633 Corded Phone
I HAVE A KX-T7633 AND IM TRYING TOGET MY PLANTRONICS CS55 TO WORK WITHOUT UN-HOOKING THE HAND SET
You can use the cord part number 78333-01. (I have included the link.) This will replace the cord that is plugged in between your CS55 charging base and the handset jack on your phone. It will plug into the base of the CS55 and the round headset jack on your phone. You will not have remote answer. Push the headset button on your phone and then press the headset button on the CS55 headset.
Good luck from Headsets Direct!
May 31, 2011 | Panasonic KX-T7633 Corded Phone
I have the Panasonic KX-T7633 and the LCD display is blank, not sure what I did. I have unplugged and plugged back in but still no display
The phone works on the outer pins of a 4 conductor base cord. Check the cord to make sure it has 4 pins and then move it to a location that works. Also, make sure you're plugged into the right hole on the base of the phone...there are 2.
Carl
May 10, 2011 | Panasonic KX-T7633 Corded Phone
I have a phone system in my house using the KX-T7633 model corded phones. I want to plug in a cordless phone in the back of the KX-T7633 so that I can be cordless, but when I do I can not get a dial tone...
In a TDA-30/50 there are FOUR super hybrid ports, the first 4 on the cabinet. In a TDA 100/200/600, there are NONE. Which one do you have and is your extension 101-104? If not, it won't work. You can probably wire an analog port to the first pair and use the same cable, but it will never merge with the digital set.
Carl
Aug 24, 2010 | Panasonic KX-T7633 Corded Phone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
How to set time on Panasonic KX-T7633
From the system administrator's phone, enter programming and dial 000 and follow the prompts using the FWD and CONF button to move the cursor back and forth.
Carl
Aug 21, 2009 | Panasonic KX-T7633 Corded Phone
1) Press PROG.
YBC (/\)
Jun 23, 2009 | Panasonic KX-T7633 Corded Phone
Need to set the time on a Panasonic KX-T7633
From the phone plugged into jack 1, usually 101, press PROG **1234 000 enter. Your date and time is changed using the arrow and NEXT keys and ENTER sets it after you're done.
Carl
Nov 18, 2008 | Panasonic KX-T7633 Corded Phone
Registering a new cordless handset
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
Sep 28, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
