Question about True TD-95-38-LT Beverage Cooler
True 2 door light problem
Have a true 2 door sliding door cooler that the lights flicker think it is either ballast or a starter but were do i find these items in the cooler.
  • 122 Answers
I believe that unit has a ballast tucked in somewhere in the compressor compartment. It may be easier to access from the back of the unit. I don't think it has a starter.
Posted on Sep 23, 2009
refritech08
  • 149 Answers
SOURCE: RE: true T-49
check the hinge position it's probably off line
Posted on Aug 02, 2008
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
Posted on May 20, 2009
projdoc
  • 2237 Answers
SOURCE: flourescant lights flickering
is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
Posted on Aug 26, 2009
  • 117 Answers
SOURCE: true cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Posted on Jan 08, 2010
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
Light bulbs in fridge both wont come on, but worked yesterday? Don't think they both could have burnt out over night?
The switch, the ballast, starter if it uses one, any one of these items can go out seemingly overnight especially the ballast or starter. I'm betting on the ballast.
Jul 05, 2013 | True TCGG-48-S
Where is the starter location for lighting
Believe me Joe I'm right there with you I work on this stuff every day and I am so stressed also. Is this the cool with the sliding doors and the compressor on the bottom? If you take off the ventilation slat cover there is a small cover right in the center the compressor plugs into that cover pull the cover off of that and the ballast is inside there.
Feb 26, 2013 | True GDM-33-C Refrigerator
GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Light flickering-it won't turn on.
starter cap in the light base. usually a silver metal or white plastic can. twist it to unlock it and pull it straight out. replace it with the exact type. you can get them at any hardware store. if your light doesn't have one, you'll need to replace the ballast inside the base. if the hardware store does not have one, you'll have to look online. try www.partselect.com.
Nov 13, 2009 | True GDM-49-RC Refrigerator
Flourescant lights flickering
Aug 25, 2009 | True GDM-12 Refrigerator Commercial
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
May 20, 2009 | True GDM-7 Beverage Cooler
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
Aug 14, 2008 | True TBB-2 Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
True TD-95-38-LT Beverage Cooler Logo
346 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
