Question about Whirlpool Refrigerators
Fishy odor, how to clean or remove odor
I spilled the fluid from some defrosted crab legs in the refrigerator, and can't seem to get the odor out. I tried soapy water and vinegar to no avail. How can I best remove the odor.
Www.naturesfresh.net problem solved removes unwanted odors
Posted on May 29, 2009
  • 33 Answers
This is a trick my wife uses when she stores fish in the refrigerator. Put about 2 cups of vinegar in the refrigerator and leave it there for 4-6 hours.
Let me know that works for you and please rate this!
Posted on Dec 09, 2008
BAD ODOR FROM DEFROSTED CRAB
I would suspect a leaky condensor,or leak in the refrigeration system,its gas oils are leaking out giving off an odor.get a professional refrigeration techncian to repair it ONLY!!!!.Warning do not try it your self.Harmful gases.
Apr 25, 2012 | Whirlpool Refrigerators
A bag of crab legs leaked how to get odor out and is there a drain an if so how do you clean it? I have cleaned with clorox.
it does have a drain but it's not for this / to clean it use hot water and a tukey baster . the hot water will clear the tube and algi ect . mm the odor is best removed with baking soda. / wash it with soda and leave a box in the frig . mm
Aug 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fishy odor
Make sure you wash the refrigerator and freezer with a baking soda and water solution.
Then, place a few charcoal briquets in the fridge and freezer areas.
The charcoal will absorb odors. It works wonders.
In one month, you can remove the briquets and scrape the outer layer off to renew the usefulness of the charcoal.
Oct 09, 2009 | Refrigerators
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 1 year old maytag refrigerator that for the last few days has a fishy smell that we can't get rid of........help what could be the problem? Thanks.
check every nook and cranny for food that could have been spilled out, if you cant see any thing crimple up 10 to 15 pages of newspaper, this will absorb any odors, repeat if needed
May 07, 2009 | Maytag MBB1956GES Bottom Freezer...
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan blows out a smell from underneath fridge could it be leaking gas.
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Jul 02, 2006 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
359 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
