Question about Sega Game Gear Console
Sega Gamegear Wont turn on
Just dug my gamegear out of the closet (actually found it when I was looking for something else) anyway, I charged the battery pack and installed new batteries, trying both. When you switch it on, the red light comes on and the screen powers up just for a second, then both go off. What could the problem be?
  • 2 more comments
  • Anonymous Feb 27, 2009
    Exactly the same as above, any help would be great
  • deckiea May 19, 2009
    exact same new batteries powers up for under a second and no more
  • IshrahSan May 11, 2010
    Have any of you tried using it with the power adapter plugged in instead of using batteries?
  • Stuart May 11, 2010
    Same thing happens when it turns on without a game inside it?
    More than likely its the system itself.
I had the same exact problem. I took the back off, pressed on each of the capacitors. Carefully put the cartrige in with the back still off, plugged in the power and turned it one and presto, it started working!!!
Here's a picture of the capacitors and another solution if my easy fix doesn't work.
http://members.optusnet.com.au/eviltim/ggrgb/ggrepair.html
Posted on Oct 02, 2009
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
Dyson will not start
If the power cells are operational and it will not start; then either the motor is dysfunctional or something is jammed in the intake module. A conduction test with instrumentation can indicate if the motor is the problem, the power cells are not fully charged, or you have a short circuit. Check Fuses.
Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
Found a Norelco 955RX in sons closet. Will shave using electric cord ,but will not charge.In removing the cover I find the batteries are corroded. Is the razor worth repairing? If so, is there a repair...
It is a good model shaver. .
You will find the correct replacement battery offered at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
You will also find a video tutorial on this page to halp show you how to open the shaver. See link below for another video with additional installation tips
http://www.shaveroutlet.com/shaver_battery_replacement
If you are not equipped to do the repair, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jun 06, 2011 | Health & Beauty
Why won't my game gear run off batteries?
I would check the battery contacts on the gamegear to make sure that no other batteries have leaked already. If it does look like batteries have leaked in the gamegear before you are going to have to clean it all up.
Have you tried to power the gamegear with an AC adapter? Usually you can pick up a universal adapter at Wal-mart for like $10 you just have to make sure it can do 9V.
Jul 04, 2010 | Sega Game Gear Console
I have a magnavox dvd vcr combo mwd2205 The dvd
No solution just the exact same problem:
Does anyone know how to fix the DVD motor? I bought this from Walmart a few years ago and after about 1-2 yrs that was the 1st thing that went on it. The VHS still plays fine. I got tired of trying to "clean" it and its been packed away for at least 2 yrs. I recenly dug it out of the closet but of course its out of warranty. Is it worth repairing (its virtually brand new) or just get something else? Thanks for any suggestions in advance.
Nov 12, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Aug 10, 2009 | Canon PowerShot SD1000 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Vivitar 2800
1 Does it give the normal little charge up whine when you turn it on?
2 Are the battery terminals clean?
3. Double check with new out of the packet top quality Duracel or Energiser batteries. Don't waste your time testing anything like this with mediocre or average batteries.
4. If you have to ask if you could fit new capacitors yourself, the answer is DEFINITELY NOT. These caps are not like on a computer motherboard: These can stop your heart.
5 Some of the big camera shops can give you a free repair quote, or if not will deduct the cost of a declined quote from the price of a new flash.
Anyway, good luck.
Jul 13, 2008 | Vivitar 2800 Flash
Sega Game Gear Console Logo
3,937 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
