Question about E-Machines eMachines Desktop PC
Emachines W2888 will Not Start up
Daughter's computer had funny smell.Then it just shut down.I replaced Power Supply and there is a light on inside on the Mother Board.But Nothing else works,no fans,nothing. It doesnt start.Is there something else I can try.Thank you so much for any help.Janie
    Scholar:
  • 86 Answers
Most likely the system board has failed. If the power supply had blown it is not unusual for the subsequent spike to blow the system board. On the other hand it may have been the system board that failed and the PSU is ok. Emachine system boards are rubbish
Either way you will need a new board and most likely a reinstall of the OS
Posted on Dec 09, 2008
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
Inside I smell something burning and my power port is loose.
Your Notebook PC needs a new power supply or at least a new power port, or it may self-destruct really soon (like tonight). Unplug your PC and quickly backup your important data to a flash drive.
I wouldn't plug anything into the power port until it gets service, and unplug it overnight (or there could be a fire).
The owners' manual doesn't describe power supply replacement:
http://support.gateway.com/emachines/Mobile/eMachines/M2350/M2xxx_030804.pdf
Here's a picture of the bottom of the system:
http://support.gateway.com/emachines/Mobile/eMachines/M6810/M6810bv.shtml
Jan 17, 2011 | E-Machines M2352 Notebook
Have a e machine fan runs but connect monitor to another computer it works. smell a burning smell when turn on pc. Got it to come up once by unplug power hold on button 45 seconds plug in and turn on came...
The smell is the Power Supply.
Typical example of a Power Supply not installed in a desktop computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4435072&CatId=106
[ NOTE*
This is not an example of a direct replacement Power Supply for your computer. I would need to know the Model Number of your eMachines to give exact information ]
Bad Power Supply. Weak voltage power rail. (Or rails. There are three main voltage power rails for a Power Supply used in an eMachines desktop computer)
Enough power to light LED lights, and apparently spin fans, but Not enough to turn the Processor on.
Watts = Voltage times Amperage.
One measurement used for measuring the maximum available power output, of a desktop Power Supply, (SMPS. Switched-Mode Power Supply), is to state the Maximum Wattage available.
Typical maximum Wattage available for a typical eMachines Power Supply, usually averages from 150 to 300Watts.
1) ALL of the LED lights on at one time, will use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
(Note* Intel Pentium II processors use less than 51 Watts)
Solution is to replace the Power Supply.
This isn't as hard as it 'sounds', if you have never performed this procedure before.
I know you can do it.
1) http://www.fonerbooks.com/r_power.htm
2) http://www.videojug.com/film/how-to-install-or-change-my-computers-power-supply
3) http://computer.howstuffworks.com/power-supply.htm
If you need guidance in replacing the Power Supply in a step by step for your eMachines, please post in a Comment. (Believe upper right of your page)
Should you also desire recommendations to compare for a Power Supply, I would be happy to provide them.
Regards,
joecoolvette
Dec 01, 2010 | E-Machines eMachines Desktop PC
Last night I heard a loud pop sound come from my computer and then it shut down. I tried to start up the computer but it didn't turn on. None of the fans turned on either so I concluded something is wrong...
Yes, and the power supply needs replacing.
4 screws hold the power supply to the cabinet or case these are usually located outside visible at the fan vents at the four corners.
Apr 19, 2010 | Ultra Products Ultra LS500 Lifetime Series...
When i plug my dvd writer to the power supply it keeps causing my computer to shut down and start back up then shut down again
It has gone faulty and is causing a power overload and this causes the PC to shut down, so it will not be damaged. Either the power supply Inside the DVD is faulty or the DVD, is.
Feb 27, 2010 | E-Machines eMachines Desktop PC
Emachines W2888 not turning on
Easy fix! Sounds like you bought a bad Power supply. Purchase an identical p.supply and it will run like a car!
Jan 27, 2009 | E-Machines eMachines Desktop PC
E Machines T2895 Power Supply
You motherboard is damaged ,you need to buy a new motherboard.
Jul 29, 2008 | E-Machines eMachines Desktop PC
Emachines shuts down by itself all the time
There are a lot of problems with Emachines as far as motherboards go. Since you've already replaced the power supply, it's safe to say that it's not causing your issue.
Since you seem comfortable with the inside of your machine, go ahead and take out all unnecessary components. If you've left your machine the way it was since you've bought it, start with the modem card that's in the bottom PCI slot. Often, those can cause issues with the computer not starting up, staying on, etc.
Also ensure that the machine is free of dust, and that all cables and connections are secure. Try not to let things float freely, and make sure you're plugging the machine into a surge protector, and not directly into the wall.
Apr 08, 2008 | E-Machines eMachines Desktop PC
No power to my emachine pc
You need to replace your power supply or have a technician do it. You can get one for $25-30.
Nov 08, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
74 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
