Question about Linksys Wireless-G Broadband Router
The model the make and model is linksys wireless-G24 ghz broadband router....(model) WRT54G v5
  • 104 Answers
Hi Sharmelle1, thanks for this info - I think you wanted to secure your wireless connection? I don't know if you've tried to do this already, so will set this out as if this is your first attempt.
Note: use a wired connection to the router when changing the router configuration.
There are four main steps. They are the same for most routers, but I have used the linksys manual for specifics.
1) Login to your router:
Open your web browser as if about to view a web page, but instead type the router address in the address bar. For this router, it is http://192.168.1.1 (note, there is no 'www')
Enter the username and password when requested. If you have never changed these, the username should be left blank, while the password is admin.
You should then see a configuration screen (the user interface).
2) Change the router password.
Click the 'Administration' option, then 'Management'
You should see the option to enter and confirm a new password for your router (click 'save settings' when finished...)
3) Change the SSID (router name):
Click the 'Wireless' menu option and 'Basic Wireless Settings' (Wireless Network). The SSID (router name) is displayed on the page. The default is 'linksys'.
It's best to change this to something else (anything is OK, as long as you can remember it. But not something that could identify you, or your location.)
4) Enable encryption
Still in the 'Wireless' menu option, click 'Security'. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
I would leave the default settings, but in the box marked WPA shared key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have secured your network, and can close the screen.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Dec 13, 2008
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
Where can i download the installer for wrt54g v5 router?
using the official linksys site you can find the drivers and other downloadable content for your specific router type.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G/download
good luck hope this helps
Oct 13, 2010 | Linksys Wireless-G WRT54G Router
I have a WRT54G -V5 which works great with all my home PC's. Have purchased itouch and it does see my Linksys device and I do know the password but when I put that in itouch it does not connect. The...
You are looking for a Wireless Security key, this is not the Linksys password for the admin portion, look on the bottom it maybe there if not changed. Else goto the router home page and check it there something like 192.168.0.1. or 192.168.1.1 etc etc
Sep 05, 2010 | Linksys WRT54G Wireless-G Broadband Router...
INstallation instructions Linksys wireless-G 2.4 GHz 54Mbps broadband router Model No. WRT54G V8
By default the box will work (box is pre-configured).
For your ref. i am providing you the link with basic configuration steps.
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
Jun 04, 2009 | Computers & Internet
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Where can I get another installation CD?
You more than likely do not need an installation CD to get this router running. For what it's worth, you can download specs, firmware upgrades, etc from the following link:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&packedargs=sku%3DWRT54GS&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187945678B01&displaypage=download#versiondetail
Hope this helps.
May 19, 2008 | Linksys Wireless-G WRT54G Router
Installation broadband router linksys WRT54G v5
In your internet explorer address bar, type in the ip address of 192.168.1.1 and see if it asks you for a password.
If that isn't it, try 192.168.1.245.
The default password is admin. No username.
Also, go to www.linksys.com and they have free chat support and can walk you through this issue.
Apr 30, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Linksys wireless-G 2.4 GHz broadband Router
What is the model No. of the router ?
You can open the setup page by typing 192.168.1.1 in the address bar of Internet Explorer / Firefox.
The default password for linksys routers is admin.
Once in the setup page, click on wireless and click wireless security. There you'll find the wireless security keys.
Hope that helps :)
For information on wireless security, click here.
For the updated list of firmwares, click here.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
