Question about Sanyo VWM-900 VHS VCR
Have cable tv and wanting to tape a certain channel
How do i get the vcr to bring in more channels if i dont have a remote is there a way to bring up the vcr menu without a remote?
  • brandon_l198 Dec 11, 2008
    i dont have a cable box i have a cable line. The cable line is hooked up to the vcr. but the vcr wont bring up all the channels i get. But when i turn the vcr off i can get all the channels.
    Sergeant:
  • 291 Answers
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
Posted on Dec 10, 2008
  • Daniel Martinez
    Daniel Martinez Dec 14, 2008
    I see what you mean........thinking........thinking.....I think that you should disconnect the vcr from the power [a/c] for at lease a day. there is a special circuit that " remembers " and it must be discharged.Reconnect the 'cable' wire and turn on the vcr. If I am correct the vcr should start "scanning" for channels. what ever channel 'locks' in will be the channel that vcr can accept.
I was able to connect a dvd player to old tv with a rf modulator.now is there a way to hook up a vcr on same rf modulator so as not to change connections each time you want to watch the vcr with instead of...
well...the reason its sooo hard is that this modulator is not intended for this use. its used for BIG jobs. you can normally do what you want with a simple rf modulator you buy at walmart or radio shack as it has a cable in and cable out, but
You dont even need a rf modulator.
The VCR can do it for free simply; hook the yellow , white if your vcr has red as well (depending on how old )...BOTH or all Three color to color from VCR(INPUT) to DVD
then use a piece of coax cable from the vcr out to tv.
test vcr by making sure that it work on either channel 3 - or 4 on tv. (leave VCR on)
Then to test your DVD connection first turn DVD player on.;.Then on front of VCR press channel down ON VCR until it says L1 or L2 this is under channel 2 when channel downing.
you should now see the dvd player on screen on either L1 or L2 depending on vcr.
now buy doing this your vcr must be on the L1 (L2) anytime you watch a dvd but when you want to watch a tape you just put it in and press play since TV itself is never changed.
when you want to go back to dvd,...stop tape and should still be right on the L1 or L2 again.
Aug 05, 2011 | Channel Vision E-1200 Video/audio Rf...
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Feb 11, 2008 | RCA VR348 VCR
Hitachi VCR and Phillips Magnavox TV
Mentor, sounds like it`s wired incorrectly or your using RCA cables (yellow, red, white ends) out of the vcr into the tv, If your using RCA cables the tv`s "input" (on the remote) has to be switched to "video input 1 or 2" etc to see the vcr tape. If you want to see the vcr`s picture on channel 3/4 you have to tell me if your using a cable or sattelite box and then I can tell you how to wire it with the coax cable, let me know, BMW Rider
Feb 07, 2008 | Televison & Video
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Sanyo VWM-900 VHS VCR Logo
140 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
